http://marp.retrogames.com/index.cgi?mo ... t=^aerofgt
I tryed these old inps...
3rd = 656,200 (dsync at boss 2)
6th = 480,200 (dsync at 1st boss)
I tryed all I know...
NO SOUND
FSKP = 0
WINDOWED
RDTSC YES
Tryed other versions w74, w75...
Tryed to use an old romset to aerofgt...
Tryed to disconect from internet...
Nothing! I lost/forgot something? Any help?
PS.: Rodrigo Lopes have the same dsync in your PC.
Aero Fighters - wolf74u1
- TRB_MetroidTeam
the 656k works with sound only and the 480k works with nosound only. must have http://wolfmame.marpirc.net/wolfmameplus-074u1.zip remove mame.ini too.
- TRB_MetroidTeam
Delete MAME.INI? This is the 1st time I heard about... but I tried to delete (temporary changename)...Chad wrote:remove mame.ini too.
MAME.INI - if deleted, I need at least re-config my rompaths - DSYNC!
MAME32UI.INI - Dsync!
DEFAULT.CFG - Dsync!
AEROFGT.CFG - Dsync!
STANDARD.CFG - Dsync!
MEMCARD.??? - Dsync!
AEROFGT.NV - Dsync!
No way!
I am sure I used the w74u1 version.
With no more other choices, I suspect is something related to the ROMset. Is it possible? Some changes in the ROMset between w74u1 and the ROMset used today? PS.: With the same ROMset I have in my folder, I am able to run AEROFGT in w74u1 and in w104... so no clue.
it might be a "you in set a, me in set b" thing too... where you might have to find another computer configured with different hardware to play them back. aerofighters had some serious playback issues early in mame, surprised it worked for me now, or maybe was i thinking of another neogeo game. darn. you did delete hiscore.dat didn't you?
- TRB_MetroidTeam
Yes. I just downloaded the emulator and the romset, "installed" in a new folder in C: and try... wrong again.Chad wrote:you did delete hiscore.dat didn't you?
Well... when possible I will try to run it in other computer. At this momemet, can anyone here test if it playbacks correctly to you?
