gat wrote:"this new first place score by Gat should be DQ'd...or at least reduced to what the score is after the 3+1(4th death)"
This is the complete sentence of what you wrote, don't give partial sentences to try to change the context of the sentence.
You wrote this without first checking the facts and the rules, don't you think you should have waited until you did or is this pre-judgment allowed by all marp confirmers or just you?
the second part of that sentence is the important part. TG's settings are whacked for this track. No reason to use 5+1 for this track.
You repeatedly stated I used 4 men to start when I used 5 men to start
maybe somethign odd there. I just tried it again and it does show 5 start lives now. the first time I started watching this, it initially showed a "4" which changed to a 3 once the first pacman spawned so 4 start lives...no idea why.
anyway, i had stated that I would confirm your score after the 4th death...but your submitted score represents 5+1 so personally I didn't want to confirm that. I would have confirmed the 6k less score after the 4th death. It's not about your score personally or anything personal toward you...but using it as a tool to get TG to fix this crap of 5+1 on a track like this one.
If you have a problem with the marp rules allowing TG settings then follow the procedure to have this rule changed
well, in general I don't...but in this specific case I do cuz the flawed TG track settings.
So why then have this one game singled out for special treatment?
cuz TG didn't want to recognize a perfect game that had a score that some other scoreboard then could allow the 5+1 and 180 more points to make a claim they had the highest, perfect score possible. It was never intended to even allow the 5+1 for anything other than getting those 180 extra points...but since that was not written down...over the years that has changed where 5+1 is allowed for any score for pacman or turbo pacman now. And now it seems to have taken another step where the 5+1 is allowed for other tracks...despite being intentionally kept at 3+1 for many other pacman variants.
There you go, I actually agree with you that maximizing the points is the more difficult part of the game and I have never said anything to the contrary anywhere.
no problem there...said for this rom set since no kill screen there is no need at all to master the game by eating all the monsters on the early boards. it's not even worth the time to try that...cuz you can run 9th key boards amassing points much faster. playing another 10-20 9th key boards versus eating all ghosts is a no brainer...just play the extra 10-20 screens.
either please confirm with the (3+1) score or DQ it.
someone else confirmed it. I chose not to cuz of the TG settings. it's like a protest of those settings. I feel if I had confirmed, that is accepting the settings. I realize those are 2 different things. I would have confirmed it if you showed/edited the score to what it was after the 4th death. I am not an editor, just a confirmer...so I can confirm scores..but can't change the submitted score or make any notes in the description etc.
I confirmed your other recent pac variant submissions with no issues. you used 3+1 for each of those....so I also was taken a bit back why you would chose to use TG settings for the 5+1 for this variant versus using the mame default of 3+1. I guess just because the rules allow it ehh?
it's like hpabst and his pole position scores. he chose a difficulty even higher than TG settings...to have more cars and resulting in getting a higher potential score that can not be matched using mame default or TG settings. he is within the rules cuz as long as you play more difficult settings that is allowed...but I think there is a gray area here where the rules should not be so black-n-white or blindly follow and allow TG settings for any track. it is impossible to reach some of his scores unless you are using that same difficulty which isn't default or TG difficulty.
I hope the editors consider special notes for the gmgalax-gm track allowing 3+1 only...not TG settings.
I hope the TG track gets fixed. Someone blindly set that up without understanding the pacman history etc.
