http://replay.marpirc.net/inp/b/d/0/tek ... olf117.zip
http://replay.marpirc.net/r/punchita
Achieves 29850 - loses against second opponent with de-sync seeming to be in the first 20 seconds of that fight.
Note: the zip file contains two INP files - one called punchita.inp which is the Wolf 0.117 INP. A second called punchita (no extension) is a non-Wolf INP which playsback to the end correctly to 81440 (playback ends immediately after a fight & is left playable).
Tekkaman@AIVA - punchita - 362,070
Re: Tekkaman@AIVA - punchita - 362,070
I get the same 29k and 81k, need third to zero. pngs are not qualifiable enough to keep a score entry at marp.
