.61 playback issues
- MARPaltunnel Wrists
.61 playback issues
Here is a current list of all playback issues (that aren't mine) from version .61. If someone wants to list issues for mine, please do so below.
All scores can be found here: http://marp.retrogames.com/index.cgi?mo ... nconfirmed
http://marp.retrogames.com/inp/krf_yesnoj_40_win61.zip - Score should probably be zeroed due to unfamiliar scoring system. viewtopic.php?t=9266
http://marp.retrogames.com/inp/tjw_arca ... mame61.zip - Does not playback as advertised for 2 people. viewtopic.php?t=9461
http://marp.retrogames.com/inp/db_cstle ... mame61.zip - Possible leeching issue. Will not confirm. viewtopic.php?t=9458
http://marp.retrogames.com/inp/wpc_grav ... _win61.zip - Does not playback as advertised for 1. viewtopic.php?t=9540
http://marp.retrogames.com/inp/tjw_jits ... mame61.zip - Awaiting on new baseball scoring system. viewtopic.php?t=9434
http://marp.retrogames.com/inp/krl_mk2c ... mame61.zip - Does not playback as advertised for 1. viewtopic.php?t=9541
http://marp.retrogames.com/inp/krl_mk2r ... mame61.zip - Does not playback as advertised for 1. viewtopic.php?t=9541
http://marp.retrogames.com/inp/krf_mtra ... _win61.zip - Chad can play it back. Please confirm. viewtopic.php?t=9295
http://marp.retrogames.com/inp/kid_pira ... _win61.zip - Does not playback consistantly to advertised score for 2. viewtopic.php?t=9534
http://marp.retrogames.com/inp/krf_rbibb_17_win61.zip - Awaiting on new baseball scoring system. viewtopic.php?t=9434
http://marp.retrogames.com/inp/pka_rbibb_3_mame61.zip - Awaiting on new baseball scoring system. viewtopic.php?t=9434
http://marp.retrogames.com/inp/kal_tfrc ... mame61.zip - kfx can play it back, please confirm. viewtopic.php?t=9457
-roncli
[Poor sig. --SarcasmCli]
Re: .61 playback issues
as this is a ton of stuff it would be nice to have marp links too to the games, but alas.
you mean starred? a job for pat if so.http://marp.retrogames.com/inp/krf_yesnoj_40_win61.zip - Score should probably be zeroed due to unfamiliar scoring system. viewtopic.php?t=9266
http://marp.retrogames.com/inp/krf_shoo ... _win61.zip - Wrong recording uploaded. Should possibly be *ed. viewtopic.php?t=9526
Lets give some time to timmykins to give the options on this one.http://marp.retrogames.com/inp/tjw_arca ... mame61.zip - Does not playback as advertised for 2 people. viewtopic.php?t=9461
zeroedhttp://marp.retrogames.com/inp/db_bbakr ... mame61.zip - Needs to be zeroed, does not playback as advertised for 3. viewtopic.php?t=9462
someone more qualified with this game needs to edit this one.http://marp.retrogames.com/inp/db_cstle ... mame61.zip - Possible leeching issue. Will not confirm. viewtopic.php?t=9458
playsback in 98 fine.http://marp.retrogames.com/inp/krf_gtmr ... _win61.zip - Unable to playback. viewtopic.php?t=9527
I'm tempted to zero this one, especially since others playback ok, but it's only been a week someone else should try.http://marp.retrogames.com/inp/tjw_hoga ... mame61.zip - Does not playback as advertised for 2. viewtopic.php?t=9465
make that 2, but too soon to call.http://marp.retrogames.com/inp/kid_intr ... _win61.zip - Does not playback as advertised for 1. viewtopic.php?t=9523
zerod. his or her other two recordings also required nvramhttp://marp.retrogames.com/inp/yod_irrmaze_7_mame61.zip - Requires NVRAM. Should be deleted. viewtopic.php?t=9524
right awaiting.http://marp.retrogames.com/inp/tjw_jits ... mame61.zip - Awaiting on new baseball scoring system. viewtopic.php?t=9434
if you read carefully you're the onlyone that can't play it back they're talking about ccastle3 recordings, this plays back fine in win98.http://marp.retrogames.com/inp/krf_mtra ... _win61.zip - Should be zeroed, does not playback as advertised for 3. viewtopic.php?t=9295
not familiar enoughhttp://marp.retrogames.com/inp/kid_naug ... _win61.zip - Should be zeroed due to leeching. Also, special rules for the game need to be updated. viewtopic.php?t=9452
zerod.http://marp.retrogames.com/inp/tar_skyb ... _win61.zip - Does not playback as advertised for 2. viewtopic.php?t=9507
confed.http://marp.retrogames.com/inp/db_sngka ... mame61.zip - Chad can play it back. Please confirm. viewtopic.php?t=9467
ok, i don't have the redump so cant confirm.http://marp.retrogames.com/inp/kal_tfrc ... mame61.zip - Playsback with the sound redump, I just haven't had time to confirm it yet. If you've played it back, please confirm it. viewtopic.php?t=9457
Playbacks fine to stage 11, score 50200. Then the cursor starts jumping all over the place. Makes 3 persons not being able to playback it.http://marp.retrogames.com/inp/tjw_hoga ... mame61.zip - Does not playback as advertised for 2. viewtopic.php?t=9465
No luck here either. 3 persons here too.http://marp.retrogames.com/inp/kid_intr ... _win61.zip - Does not playback as advertised for 1. viewtopic.php?t=9523
-Abbe
Agreed. 50200, then it goers into spasms.Abbe wrote:http://marp.retrogames.com/inp/tjw_hoga ... mame61.zip - Does not playback as advertised for 2. viewtopic.php?t=9465
Ray
"You can tell whether a man is clever by his answers.
You can tell whether a man is wise by his questions." - Naguib Mahfouz
ok hogan's is gone 4 people can't play it back. and intrepid gone 3 people can't.
Sampras has another underneat it
http://marp.retrogames.com/inp/kid_intr ... n37b11.zip
For yesnoj, no, it's already *ed. The score should be 0'ed. The minigame that he got the 40 points on is *NOT* how the game is scored, seeing how there are several different types of minigames, and the scoring systems for them are not all the same.Chad wrote:you mean starred? a job for pat if so.http://marp.retrogames.com/inp/krf_yesnoj_40_win61.zip - Score should probably be zeroed due to unfamiliar scoring system. viewtopic.php?t=9266
For shootbul, yes, that does need to be *ed, although I didn't know Pat was the only one who could do it.
I'm just thinking I should run a poll for it. I thought that leeching to increase lives was illegal in general, which is what this is.Chad wrote:someone more qualified with this game needs to edit this one.http://marp.retrogames.com/inp/db_cstle ... mame61.zip - Possible leeching issue. Will not confirm. viewtopic.php?t=9458
But it's still in the list.Chad wrote:playsback in 98 fine.http://marp.retrogames.com/inp/krf_gtmr ... _win61.zip - Unable to playback. viewtopic.php?t=9527
Ehhh? I was under the assumption that neither you nor JoustGod could play it back. In any case, go ahead and confirm it.[/quote]Chad wrote:if you read carefully you're the onlyone that can't play it back they're talking about ccastle3 recordings, this plays back fine in win98.http://marp.retrogames.com/inp/krf_mtra ... _win61.zip - Should be zeroed, does not playback as advertised for 3. viewtopic.php?t=9295
You don't have to be. The poll was vastly against the type of leeching demonstrated in that recording. It's obvious what the player does if you watch it.Chad wrote:not familiar enoughhttp://marp.retrogames.com/inp/kid_naug ... _win61.zip - Should be zeroed due to leeching. Also, special rules for the game need to be updated. viewtopic.php?t=9452
I'll do this one tonight.Chad wrote:ok, i don't have the redump so cant confirm.http://marp.retrogames.com/inp/kal_tfrc ... mame61.zip - Playsback with the sound redump, I just haven't had time to confirm it yet. If you've played it back, please confirm it. viewtopic.php?t=9457
-roncli
