The DIP switch checker is usually updated for tournaments and
distributed to all judges. It is not reserved for editors only.
However, it is far from being an overall checker. Yes, Brian is
correct, you can look at the source code to find out how the DIP
switches are stored in the .inp. The bad parts: (1) The overall .inp
format has changed at least three times, (2) there are 3000+ games in
MAME, and (3) The DIP switch parts of game drivers are changed every
now and then, so if you know which bit corresponds to which DIP
switch for a given version of MAME, that does not mean it's the same
bit in a different version of MAME, even regardless of whether the
two versions use the same format as mentioned in (1) . Is anybody
volunteering to MANUALLY add support for 5000+ combinations of MAME
versions and games to the checker?
Also, the checker at this point is written in a way to see if the
correct settings are used. Most of the time when there is a
tournament, I look at what the required settings for each game in
that tournament are and then manually add each game to the checker.
Then it can be used to compare the settings of SOME PARTICULAR
VERSION of MAME (so not just any version) of a given .inp to the
required settings for that game.
So, again, it's not a one size fits all utility. Actually, it's a one
size fits only a handful utility, with by far the majority being
unsupported. So most of the time when I want to see which DIP
switches were used in some recording, I can't even use it and have to
revert to using a hex editor and reading the source code of the game
driver...
Ben Jos.
walbeehm@walbeehm.com
