Page 8 of 14
Posted: Fri Sep 15, 2006 7:15 am
by zlk
Ben.shinobi's gunlock replay is nice. He finishes the game on one credit:
http://marp.retrogames.com/inp/a/0/7/be ... mame89.zip
It playsbacks with wolf89.
The same thing goes for his rayforce(j) recording:
http://marp.retrogames.com/inp/7/6/e/be ... mame89.zip
Posted: Fri Oct 27, 2006 1:17 pm
by zlk
Wednesday's Tengai replay is great. He finishes the game on one credit:
Posted: Tue Jan 23, 2007 1:20 pm
by zlk
Vertex-B's kangaroo recording is very impressive:
http://marp.retrogames.com/inp/c/2/4/rg ... olf106.zip
Mark Brzozowski scores 2.4m on omega race:
http://marp.retrogames.com/inp/6/f/2/wa ... olf101.zip
Posted: Thu Mar 22, 2007 7:44 am
by destructor
zlk wrote:This player knows how to play Guwange:
http://www.geocities.jp/pkbst331/
Here is a direct link to the replay section:
http://www.geocities.jp/pkbst331/replay.htm
There is a 40 million point replay, a 50 million point replay, and a 2 players at the same time replay at the site. I enjoyed watching them all.
Links are not worked. Maybe someone have these replays on HD?
Posted: Thu Mar 22, 2007 8:02 am
by zlk
Posted: Thu Mar 22, 2007 11:19 am
these i'd like to see too, where can i (we who want to see these replays) get hcmame071u2-0726pp to play these back? they do not playback in mame71 mame71u2 or mame72.
Posted: Thu Mar 22, 2007 1:14 pm
by destructor
http://www.geocities.co.jp/SiliconValley-Oakland/8859/
EDIT.
In inp folder I have guwange.inp and guwange.hrp
I use:
hcmamep -rompath c:\roms -playback guwange.hrp
Playback incorrect.
I copy hrp file to hrp and nvram folder, still the same.
Where is key?
EDIT
hcmamep -rompath c:\roms -playback guwange.inp
or
works incorrect too.
Posted: Thu Mar 22, 2007 6:19 pm
by GHEMANT
these replay work with windows 98 only if I remember well.
Posted: Fri Mar 23, 2007 12:31 am
by The_Pro
Try -playhrp
Posted: Fri Mar 23, 2007 3:51 am
by GHEMANT
hcmamep.exe -playhrp gensuke
Posted: Fri Mar 23, 2007 5:56 am
$ ./mame71u20726.exe -playhrp gensuke
failed to open gensuke for playback
$ ./mame71u20726.exe -playhrp gensuke.inp
nvram: ignore nv file
REPLAY: "guwange (Guwange (Japan))"
        recorded by "HaChiMAME "
WARNING: "HaChiMAME 0.71u2 (Jul 26 2003)" may not play back this hrp file correc
tly. [press return]
cpu[0]: M68000 C core
Average FPS: 57.550327 (872 frames)
and the screen starts a two player game that goes out of sync with a mame popup "REPLAY : playback error".
Posted: Fri Mar 23, 2007 7:07 am
by destructor
GHEMANT wrote:these replay work with windows 98 only if I remember well.
I playbacked on WinXp with no problem.
In zip file must be inp and hrp files. Unzip both to Inp folder. Use playhrp, not playback.
Wait, I will check gensuke replay. I watched sisin replay.
EDIT
OK. Gensuke replay works fine too.
What I did:
1. unzip guwange-gensuke to Inp folder. Now I have guwange-gensuke.inp and guwange-gensuke.hrp in Inp folder.
2. in maind hcMAME directory I create a.bat file. Inside bat file I write:
hcmame -rompath c:\roms -playhrp guwange-gensuke
3. Run a.bat file.
[/quote]
Probably you don't have gensuke.hrp file.
And, inp and hrp file must have the same name.
Posted: Fri Mar 23, 2007 12:42 pm
[/quote]
And, inp and hrp file must have the same name.[/quote]
thanks, des, they work now. It doesn't work with the .inp at the end you must remove the .inp and also make sure you say -playhrp with the same filename removing the .inp extension (none of the zips uncompress to gensuke.inp and gensuke.hrp so the correct commandline would be after extracting the inp and hrp to the inp folder.
./mame71u20726.exe -playhrp guwange-gensuke
./mame71u20726.exe -playhrp guwange-2p
I was disappointed that the two player wasn't a cooperative effort but a keyremapped single player using two players, but still great recordings.
Posted: Wed Jul 11, 2007 8:26 am
by The TJT
Destructor's new MARP world record on Shinobi, CONGRATS!
=D>
http://marp.retrogames.com/r/shinobi
(I assume it beats TG and Gamest records)
I remember being the first one to finish the game at my arcade back in the day...but it was so much easier since we didn't know about 50k bonuses. Getting those bonuses requires some seriously accurate timing.
Posted: Wed Jul 11, 2007 8:53 am
by destructor
20k bonuses ;) Thanks. I send this score to TG too.
