Wolfmame 150, Not workig
Shahbaz
Post by Shahbaz » Mon Oct 28, 2013 11:01 am
Hello Friends, wolfmame150 is not working on my Laptop, When i try to play the game or record the game then black screen appears, no any error message. when i press Alt-Tab button then computer shows it running. And with ESC it goes back to the wolfmame150 folder where i have opened the batch file. Can any one guide me to solve it..?? Thanks.
RAX
Re: Wolfmame 150, Not workig
Post by RAX » Mon Oct 28, 2013 1:51 pm
Do you have windows8?
During black screen is there any sound?
Try with the option -window (I've sent a message to you to do that in my batch file): if it's only a fullscreen mode problem this should solve for the moment, then we could find the best graphic mode to run emulation.
Post by mahlemiut » Mon Oct 28, 2013 7:24 pm
Sounds like it could be the issue with D3D and Intel integrated video chipsets. Try -video ddraw.
Shahbaz
Post by Shahbaz » Tue Oct 29, 2013 2:12 pm
No RAX, I am using Windows7, and i am hearing the Sound during black screen.
Yes i put (-window) in Play.bat file. But this time no whole screen black, only vertically black screen appears in front of CMD window.
@mahlemiut: where i can replace the D3D with ddraw?? Where is .ini file??
Sorry, because i am not familiar to use these newer versions of wolfmame, even Wolfmame148 is working perfect on my Laptop. (RoughRanger). and i did not try Wolfmame149 either.
RAX
Post by RAX » Tue Oct 29, 2013 2:16 pm
Edit with notepad my play.bat file
the third row is:
set MAMEOPT=
Change it to:
set MAMEOPT=-video ddraw
Post by mahlemiut » Tue Oct 29, 2013 8:00 pm
mame.ini is located in the same folder as mame.exe
If it doesn't exist, then run 'mame -cc' (without quotes), and it'll create one for you.
Shahbaz
Post by Shahbaz » Wed Oct 30, 2013 9:36 am
Thanks RAX, It's working now. (y)
Thanks mahlemiut.
ballas
Post by ballas » Mon Nov 11, 2013 9:00 am
Does anyone know where I can find a list of NON WORKING ROMS in MAME 0.150 or 0.151?
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Post by mahlemiut » Mon Nov 11, 2013 9:12 am
In 0.151, out of 29,610 drivers, 20,004 are marked as not working. A large number of those are likely to have mechanical parts to them, and has such, are likely to never be "working".
ballas
Post by ballas » Mon Nov 11, 2013 9:26 am
Thanks, what I am trying to get at is there ever say games that worked in wolf 0.106 that later on does not work on let's say version 0.150 or are there only games added from one version to another. I know you need teh proper roms for a certain version of MAME.
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
