hang on / super hang on / hang on jr....<issues>
negative1
Post by negative1 »
ok,
i've put up a new high score for
hang-on jr....
1st
Hang-On Jr.
(hangonjr) negative1 (@) 21 Oct 02 23:52:56
638,910
1 man .. / this is not a JUNIOR version, its very hard..almost made it to end of stage 4 .. / no .NVRAM file, but use no sound to playback .. / used logitech wingman for movement+accelerate
but dont be fooled by the name,
its VERY HARD..in fact, i haven't gotten past
stage 4 yet..and the settings are already on
the easiest..i can't imagine what the harder
ones are like!
1 bump or crash, and its game O V E R...
also..
does anyone play hang-on, or super hang-on?
i've noticed some sprite problems in super hang-on,
when you don't move, you're invisible....this is
referring to the WIN61 version....
i think all the other replays are from mame36, and win36..
are there any current versions that play correctly?
thanks..
later
ne g ativ e 1
sikraiken
Post by sikraiken »
Answering the 'problems' in Super Hang On, the game only works (correctly) in older MAME versions. Currently, they are rewriting the System 16 driver, so somethings don't work all 100% still. (do I have the right driver?) "2006"
RE
Post by QRS »
I think you have to play it with mame 36 final or earlier.
Super Hangon and Outrun my favorite racing games.
I suck on Hangon and Hangonjr. I don´t like them so much.
I see the exact same thing for those games in version 60.
I'll have to try an older version as noted above to see if it's ok there. It is hard to play when you can't see your guy except in turns...plus parts of the environment also aren't drawn.
negative1
_new_high_score_
Post by negative1 »
FINALLY got past the novice stage..
geez, is this game HARD!
i switched controls to have accelerate/decelerate to
the buttons (instead of joystick up/down)..
details
1st Hang-On Jr.
(hangonjr) negative1 (@) 28 Oct 02 20:48:38
1,358,460
1 man .. / this is not a JUNIOR version, its very hard..finally got to past novice level (and nearly crashed on last stage)..then got to level 8 .. / no .NVRAM file, but use no sound to playback .. / used logitech wingman for movement+accelerate, changed accelerate/decelerate to buttons
qrs, you should try this or hang-on (i still can't finish that
either)..
the ai logic for the bikes is easier than 'super hang-on'..
although the gameplay is slower..
later
n eg ati ve 1
