Safety Spot
Gorf Safety Spot
Post by Zhorik » Fri Feb 04, 2005 1:32 am
It doesn't work in the gorf ROM set with current versions of MAME. If you notice, the screenshot above was from the gorfpgm1 ROM set which is better emulated. It worked in the arcades too, but the emulation for the gorf ROM set is not very accurate and has a lot of other problems besides just the safety spot not working.
-gastrainga
re....
Post by AL » Fri Feb 04, 2005 8:06 pm
Gaz: just leave the last laser guy,and then go extreme left and extreme up.
Should work. Must be a MAME thing. It worked in the arcades. Maybe a newer rom version made it impossible. I used gorfpgm1 ROM set .
re....
Post by AL » Fri Feb 04, 2005 8:24 pm
And while we're at it, lets not forget about the old Defender safe spot.
Collect all ten humanoids, wait until there are no enemies on screen, and land those MF's....
Only really works on wave one, unless you are a master. But gives you an opportunity for an early smoke etc....
defe0000.zip
(1.31 KiB) Downloaded 251 times
QRS
Post by QRS » Fri Feb 11, 2005 7:27 pm
Hisa:
Talking about safespots.. are there any of these on some of the later bosses in strikers 1945 plus? 1-6, 1-7, 1-8 (or the semibosses) Maybe on the second loop? Even if I need one to even get to the second loop hrm :)
Thanks
QRS
wuzel
Post by wuzel » Tue Feb 15, 2005 3:31 am
Commando - i think all romsets
stage 3 - behind the bunker to the right :)
while old days at arcades the chef of it while spotted some1 standing there simply cutting the power off :)
It's good 2 be here with U guys :)
Tron
Post by The TJT » Tue Mar 08, 2005 6:53 pm
The more or less famous Tron safety spot. Works at opposite corner too.
Time for a smoke, again
Novice
The greatest info supplyer
Re: Safety Spot
Post by Novice » Sun Feb 19, 2017 4:36 am
Raiden #8 last.
I think this is the KING of the safety spot.
DEFence CONdition
WAR 1<< >>7 PEACE
Novice
Re: Safety Spot
Post by Novice » Tue Dec 25, 2018 12:32 pm
R-Type II boss 5.
DEFence CONdition
WAR 1<< >>7 PEACE
Novice
Re: Safety Spot
Post by Novice » Tue Dec 25, 2018 12:33 pm
and boss 6(last)
DEFence CONdition
WAR 1<< >>7 PEACE
Kale
Re: Safety Spot
Post by Kale » Tue Dec 25, 2018 2:29 pm
Robocop stage 5 boss
Novice
Re: Safety Spot
Post by Novice » Mon Jun 03, 2019 8:16 pm
raiden II boss 5.
there are 3 positions.
A:side
B:back
C:front
ABAABABAABCBAABABAABCBAABABAABCBAABABAABCBAA .
after 44th attack(A), boss will escape.
The attachment 0002.png is no longer available
DEFence CONdition
WAR 1<< >>7 PEACE
