[K9] Round 3 - Slap Fight (Japan set 1) [slapfigh]
Re: [K9] Round 3 - Slap Fight (Japan set 1) [slapfigh]
The score I posted is the total after beating the 4th loop boss. I died at the same time which sent me back to the third loop. Does that mean I can score more points without breaking the 4th loop rule? In any case, I opted not to add the points I got after that, it's just a few thousand anyhow. Plus I doubt people will see this as a needed strategy for this tournament.
- TRB_MetroidTeam
Despite there are 12 (or 16?) enemies between the last boss, and the exact starting point, the K9 score will be the score you have just after you defeat (by first time) the last boss in the 4th loop. And if you die just after beating him in the 4th loop, your score will finish at that moment. In other words, you are not allowed to defeat 4th loop last boss (earning the points) and respawn and try killing it again.The_Pro wrote:The score I posted is the total after beating the 4th loop boss. I died at the same time which sent me back to the third loop. Does that mean I can score more points without breaking the 4th loop rule? In any case, I opted not to add the points I got after that, it's just a few thousand anyhow. Plus I doubt people will see this as a needed strategy for this tournament.
Tip: There are many ways to increase points during the game! Good luck!
First thing to check, is that Alcon is the parent set, you'll need alcon.zip also.wolfman24 wrote:not sure what is going on but my wolfmame1.4 is saying that the rom files are missing their rom image or chd image not sure how to setup it up.
thanks for any help
Second thing to check, is that you have the MCU dump that was added in 0.139. Can't help you with this, other than to say, Google is your friend.
- TRB_MetroidTeam
Now that's official!
OFFICIAL BRACKETS HERE
An important change: Now we have another bracket (Continue Bracket) after the Losers Bracket. Players that lose (in Losers Bracket) until the Round 6 will go down to this "last chance" bracket, and can continue in the competition. See the link for details!
Oops ! before reading this here, I've edited The_Pro's score to final score.TRB_MetroidTeam wrote:Despite there are 12 (or 16?) enemies between the last boss, and the exact starting point, the K9 score will be the score you have just after you defeat (by first time) the last boss in the 4th loop. And if you die just after beating him in the 4th loop, your score will finish at that moment. In other words, you are not allowed to defeat 4th loop last boss (earning the points) and respawn and try killing it again.The_Pro wrote:The score I posted is the total after beating the 4th loop boss. I died at the same time which sent me back to the third loop. Does that mean I can score more points without breaking the 4th loop rule? In any case, I opted not to add the points I got after that, it's just a few thousand anyhow. Plus I doubt people will see this as a needed strategy for this tournament.
I'm ok with your rule, but this is not the same than Marp rule, which can be disturbing : maybe we can vote "max=4 loops" for this set ?
and keep marathon play for other sets ?
How DARE you sir!Phil Lamat wrote: Oops ! before reading this here, I've edited The_Pro's score to final score.
- TRB_MetroidTeam
Good idea!Phil Lamat wrote:maybe we can vote "max=4 loops" for this set ?
PS.: How can I "convert" that Brackets.xls to an image to add here as image? Only one image would be fine. Or one image to each Bracket, if necessary. Ideas?
ROM still not working for me. I have .140 now. I have slapfigh.zip and alcon.zip. Are there more parent roms?
Also, how do you record with .140 lol
B
B
That should be all you need. Open the zip and check all the ROMs are there.bigbee99 wrote:ROM still not working for me. I have .140 now. I have slapfigh.zip and alcon.zip. Are there more parent roms?
record.bat should be supplied. Open a command prompt, change to the folder containing wolfmame (cd <folder>) and start recording by typing (record <game shortname> <inp filename>)bigbee99 wrote:Also, how do you record with .140 lol
Well I never - unplugging the old PS2 faithful did the trick. No issue with this on 0.106.unclechicken wrote:Have you got a joypad with analog sticks on it? (Like on the PS2 and 3?) If so this made my MAME games go funny because of a bad calibration. If not, check your PM's.RichyS wrote:Not sure if it is a ROM issue, but whatever front-end I try my ship moves itself to the extreme right edge of the screen and won't move left. Running Win Vista if anyone has any clues / pointers.
<edit> OK, I think that it may be a ROM issue - same issues when running directly from command prompt - will search for new ROMs
Cheers
RichyS
Keyboard / dreadful score it is then
Cheers
RichyS
- unclechicken
- Button Slapper
I did have the above problem like I said, but go into Windows control panel/game controllers, and really configure/calibrate the joypad, move the analog thumb sticks around when it says Press all directions on the Dpad, try to get it in the centre and move it in all 4 corners.
This sometimes works.
pm sent re roms.bigbee99 wrote:ROM still not working for me. I have .140 now. I have slapfigh.zip and alcon.zip. Are there more parent roms?
B
re recording there is a good page found via the "Help" option in the middle of the MARP main menu, then choose windows commandline. The "record" and "playback" batch files should already be in your MAME 140 folder, so you don't need to add them manually.
Cheers!
- Button Masher
I'm command line challenged so I'm using the gui (I think it's Mamepgui 1.5.0 but I'm not at home right now to check). I guess I never checked to make sure it was recording properly as I spent all of my small amount of free time last night just getting the darn thing set up. Once set up though, the gui is sweet.bigbee99 wrote: Also, how do you record with .140 lol
B
MAMEPGUI and QMC2 are both good, cross-platform frontends for both MAME and MESS. Just set the NVRAM folder to NUL (or /dev/null for Linux/OS X users) and that should cover any NVRAM issues.
- ballas
- MARP Knight
If someone can please just check my submission under "ballas" on the scoreboard. I think I recorded correctly. Just want to confirm this.
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
