18 Holes Pro Golf
dan
18 Holes Pro Golf
Post by dan » Sat Dec 19, 2009 8:48 am
progolf "18 Holes Pro Golf(set 1)
This game is 18H or 9H?
Reference:
viewtopic.php?f=9&t=9414&start=0
Re: 18 Holes Pro Golf
Post by Phil Lamat » Sun Dec 20, 2009 5:26 am
I see only 9 holes has been voted.
In an other way, game's name is "18 Holes Pro Golf" so it sounds logical to play 18 holes.
Or maybe, as the game have a clone (progolfa), we can play 18 holes on progolf and 9 holes on progolfa ?
Post by Phil Lamat » Sun Dec 20, 2009 9:42 am
By the way, Dan, can you playback your own input ?
Or other people ?
I fail playing it back (desync first hole)
Post by Chad » Sun Dec 20, 2009 2:24 pm
I think the desync happens on the first swing. The decision was for 9 holes but only 5 people voted? We can have another vote. But we should be able to play it back too.
dan
Post by dan » Mon Dec 21, 2009 6:07 am
I don't know why, but the signal of the coin is not recorded in the replay file.
However, I can playback if I insert the coin at once after the game started.
This game is "18 Holes Pro Golf".
But, I think of 1-9 halls and 10-18 halls like the same course.
This game might be better with 9 holes.
Post by mahlemiut » Mon Dec 21, 2009 7:19 am
dan wrote:I don't know why, but the signal of the coin is not recorded in the replay file.
Another case of PORT_CHANGED callbacks, which are not triggered by input from an INP. It's a known bug (I should know, I posted the bug report at MAMEtesters over 7 months ago), which I guess is not high enough priority for MAMEdev to fix.
Post by Chad » Mon Dec 21, 2009 12:39 pm
I can play this back reliably with a manual credit inserted, a score of 66200 is posted for the 23 strokes of the first 9 holes, but since there is no credit required at the 10th hole, this game should allow 18 holes by default. I believe the past poll post was for games that required a credit per hole or 9 holes, this game does not so it should be allowed to play a full game. 156000 score at 48 strokes for 18 holes.
Then the question comes, should the game then be scored by points and not by strokes?
