B-Wings Rom Sets Wolf106
DKM
Re: B-Wings Rom Sets Wolf106
Post by DKM »
Listen, I'm not here argue with you, cause problems, or ask for your forgiveness because I just don't care. I'm here to play games.
If you want to discuss your feelings or a shoulder to cry on, take it to Dr. Phil.
I would like to get back to whats fun and positive.....games
Dark Tower 21,235,300 WR
simpsons99
Post by simpsons99 »
good then shut up and play some .. this last post from you shows how fake you really are.
Arcade Game Scores
DKM
Post by DKM »
[edited - let's lay off the insults, please]
may 1st
simpsons99 wrote:
Phil Lamat wrote:Everything is in proper place now, thanks Pat
phil said right everything is fine and that's after this recording was done
It looks like Phil made a mistake or changes were still being made around the time of his post.
I just checked your .inp file. Your recording was definitely done with the old bwings set in Wolf .106. When you try to play it back it says so.
C:\wmame106>mame -pb bwings
Recorded in WolfMAME 0.106
Recorded system's speed = ~2590MHz (Intel)
This recording was made with the C 68k core enabled
Start date of recording: Sat Jun 16 14:51:05 2012
Checks out OK. [553f]
Playing back previously recorded game bwings (Battle Wings) [press return]
Per both the Special Rules for bwings and mahlemiut's post on this thread, for bwings: "VERSION TO USE: Mame 112 or later. Previous "bwings" has been renamed "bwingsa" in Mame 0.111u6."
So your Wolf .106 recording of 135,330 listed under bwings should be moved to bwingsa (http://replay.marpirc.net/r/bwings - http://replay.marpirc.net/inp/2/8/2/bea ... olf106.zip).
Are you saying that your recording wasn't made with Wolf .106 or wasn't made with the old bwings romset?
if you want to have a bwings recording up, you should play it in WolfMAME .112 or later per the Special Rules for the game.
simpsons99
DKM wrote:
may 1st
so you do remember your remarks your a total lair
Arcade Game Scores
When I said 3 years ago that everything was in proper place, I was probably talking about Pat's work about clone names & special rules.
But for sure if you've recorded with 0.106, you've played with what is now bwingsa on Marp. Inp moved.
simpsons99
phil who started this post here 3 years ago for a reason.. Funny thing i was told I played the right one at the time .. Then a couple posts later you come in and something else ..
Again no one would have known anything about this if I never said anything about it ... No Credit or anything just move my score 3 years later ....
That's just neat!
Really I stopped playing this years ago because my scores where being messed with and i kept having to replay everything ..
Arcade Game Scores
...if you don't like playing the game, then don't play it. No one's holding a gun to your head.
Plus I've just discovered that you've uploaded your input (date : 16 Jun 2012) under BWINGSA, see the "a" in the link to the inp below :
That means :
1-when I've said all was in proper place, yes it was
2-later (when ? I don't know) you've moved your input yourself in the wrong place
simpsons99
No I never moved any scores .. At the time someone was moving all kinds of scores and kept taking my scores back to older ones.. I stopped playing it for that reasons .
Arcade Game Scores
simpsons99
I do have to say this different rom set is broken at Level 3 Boss there is no way to beat it
Arcade Game Scores
