Chelnov INPs to be moved
edusword
Post by edusword »
I've found three Chelnov INPs that should be moved to other romset of the game. They are the following:
1) GameGuru - 96,000 points - http://replay.marpirc.net/inp/9/4/9/db_ ... _m37b3.zip
The INP is currently in Chelnov - Atomic Runner (Japan) [chelnovj], but it was not played using that version of the game. The INP should be moved to Chelnov - Atomic Runner (US) [chelnovu]. This player already has got an INP in chelnovu (95,500 points), but it is a lower score and so this last INP should be deleted.
2) HoLeCorna - 273,550 points - http://replay.marpirc.net/inp/a/5/6/hlc ... m37b15.zip
The INP is currently in Chelnov - Atomic Runner (World) [chelnov], but it was not played using that version of the game (World version was introduced in MAME 0.53). The INP should be moved to Chelnov - Atomic Runner (US) [chelnovu].
3) Olivier Millardet - 93,150 points - http://replay.marpirc.net/inp/c/a/d/om_ ... _win81.zip
It's the same case as 2).
Regards!
Re: Chelnov INPs to be moved
All fixed.
I let you (re)confirm
il_kornutazzo
Post by il_kornutazzo »
As HoLeCorna was my previous nick on marp (before losing the password and being forced to make a new account), I wanna say this: when I played this game with my old version of mame (m37b15), I could see only 2 romsets for it, chelnov and chelnovj, but the second one didn't work for me, so I used only the first one. Checking that romset it seems to be true that later it has been renamed "chelnovu", but I can't understand how now I have 1 inp submitted under "chelnovu" (the one just moved) and another one (score 270,950) still submitted under "chelnov", if I always used the same romset and mame version. Or am I wrong? :o
Because I didn't check if you had an hidden inp behind the first one.
Now fixed
edusword
Post by edusword »
Now we have all replays confirmed and within the correct romset. Thank you! :wink:
il_kornutazzo wrote:HoLeCorna was my previous nick on marp
If you want, you can download the 2 inps made under this nick (chelnovu/niyanpai) and reupload under your new nick
