Page 1 of 2
Raiden II(Germany) problem
Posted: Sun Aug 13, 2017 7:05 am
by PP.
I tried to watch BBH's RaidenII(Germany)-raiden2g inp but no chance.
Then I saw that this rom came out in mame184, while recorded inp claims mame181.
In mame181 menu exists "raiden2g", but under the title "RaidenII(easy version, Germany)" which is/was "raiden2eg"...
So, can someone fix this mess?
Re: Raiden II(Germany) problem
Posted: Tue Aug 15, 2017 11:55 am
by ***PL***
It is not confirmed, but if BBH used m181 instead of his claimed m188, then you are correct.
As of m184... raiden2g -> raiden2eg "Raiden II (easy version, Germany)"
Posted: Tue Aug 15, 2017 9:16 pm
by BBH
it's been replaced.
Posted: Wed Aug 16, 2017 7:21 am
by PP.
Innuendo will smash anything we do, but how do you start with the blue plane?
Posted: Wed Aug 16, 2017 4:51 pm
by Kale
Insert a coin then use the Seibu Code:
Up, Up, Down, Down, Left, Right, Left, Right, B, A
Posted: Wed Aug 16, 2017 5:41 pm
by PP.
Kale wrote:Insert a coin then use the Seibu Code:
B, A are the fire/bomb buttons?
I tried several times, but always get the red plane
Posted: Wed Aug 16, 2017 6:10 pm
by Kale
You aren't fast enough.
Posted: Wed Aug 16, 2017 6:17 pm
by PP.
Fast or slow, it doesn't work.
Posted: Thu Aug 17, 2017 7:54 am
by PP.
There is also something strange, you can't see his joy/buttons moves with the command "-iv 1".
There are no indications during his playback.
Posted: Thu Aug 17, 2017 8:15 am
There's a good reason for that. I'm sure you can figure it out, it's not hard. ;)
Posted: Thu Aug 17, 2017 8:20 am
by PP.
mahlemiut wrote:There's a good reason for that. I'm sure you can figure it out, it's not hard. ;)
Is it because he used blue plane?
Another strange thing is the "power up" in "Bubble Bobble: Lost Cave V1.0",
I saw his moves with "-iv 1" (left-right-left-right-1-2-1) but do not work for me! :?: :?:
Also, he just deleted his entry in "hyprolymba"...
Our friend is full of tricks :lol:
Posted: Thu Aug 17, 2017 9:32 am
You're missing the start button.
Posted: Thu Aug 17, 2017 2:25 pm
by PP.
mahlemiut wrote:You're missing the start button.
EDIT
Ok, I solved it. So, why the start button(1) doesn't appear?
Posted: Thu Aug 17, 2017 6:57 pm
It does, you just missed it.
Posted: Thu Aug 17, 2017 7:21 pm
by PP.
mahlemiut wrote:It does, you just missed it.
And what is the key for "start"?
I made a video to watch it slowly, it only shows <- -> <- -> 1 2 1
Do you want to see it?
Where/which is the 'start' indication?
