Dig Dug
Dig Dug
NotMan
Post by NotMan »
Ok! I know what the problem is... NVRAM!
I have nvram folder disabled, but WolfMAME .118 create nvram before and after recording. The only way is to make it work is make a dummy (NULL) directory to make sure that nvram is not saved before or after recording.
Also, mahlemiut must forgotten to disabled that feature, again. :P
NotMan
You must have missed this bit from just over a year ago...
News Page wrote:Do remember that you will need to remove or disable NVRAM again (-nvram_directory NUL is the preferred method).
negative1
Re: Dig Dug
Post by negative1 »
has anyone replayed the top score on dig dug?
http://replay.marpirc.net/r/digdug
i tried the top score twice..(under mame56.. mame55 crashes with an error)..
yeah, i know its a mac file, but it says its compatible..
it stops at 204, around 3.1 million...
haven't tried don hayes 2nd place, but it doesn't work under vista..
so i'll try it on xp..
tech-d uses great techniques, including the drop rock freeze, but could
use some of dons patterns combined to make a higher score on the
earlier level ..
later
-1
Re: Dig Dug
yeah i get 3.1million too, it's possible this was confirmed by Rick (Ln2) with a mac.
negative1
Re: Dig Dug
Post by negative1 »
Chad wrote:yeah i get 3.1million too, it's possible this was confirmed by Rick (Ln2) with a mac.
darn!!! I REALLY want to see a kill screen in dig-dug, i've never seen it..
i never even knew about the slow levels either.. i always used to quit at a million, or shortly
afterward..
i wish there was some other replays or videos of this.. i couldn't find any on youtube..
later
-1
dbh
Re: Dig Dug
Post by dbh »
It's been a while since I watched TECH-D's replay but I do know I was able to watch the whole thing. I'll try and check later tonight to see if I can still get it to play back.
I'm pretty sure Ken House has a video of the kill screen on youtube somewhere. He uses "scoundrl" as his username in several places.
negative1
Re: Dig Dug
Post by negative1 »
dbh wrote:It's been a while since I watched TECH-D's replay but I do know I was able to watch the whole thing. I'll try and check later tonight to see if I can still get it to play back.
ok, found one.. i was at the classic gaming board, and someone pointed me at one..
but i still want to see it in a replay!! maybe i'll get to it, if i keep playing!!
might take me awhile though.. i'm pretty rusty..
later
-1
