Games of T11
Moderator: giro-X
Kale
Re: Games of T11
Post by Kale » Thu Mar 10, 2011 10:46 am
Ask privately to an editor like Gameboy9 or Skito about it.
gameboy9
Re: Games of T11
Post by gameboy9 » Thu Mar 10, 2011 3:41 pm
Kale wrote:Ask privately to an editor like Gameboy9 or Skito about it.
I used to be an editor here... but I retired from that position many years ago.
But... if you want confirmation rights on HARP... I'm your man! :)
http://gameboy9.marpirc.net
gameboy9
Re: Games of T11
Post by gameboy9 » Fri Mar 11, 2011 1:30 pm
Peeking at the spanish forum's T11 topic, I think it was el_fumador who had a point. (now I did use Google translator, so if I misunderstood the conversation... my bad) With each tournament in the past, each game had a judge assigned to that game so the tourney coordinator's job was made a little bit easier.
So, Potante, if you'd like to take that route, if Lode Runner, Vs. Pinball, or Outrun are selected, I'll volunteer to judge those games if you want one.
Additionally, if you don't mind an opinion about Lode Runner, if this gets selected, I wouldn't be surprised if there's a tie at 999,999 points during the tournament. If this happens, I suggest a tie-breaker of whoever gets 999,999 points first gets the higher position.
Just a couple of thoughts. Thanks!
Stig
Re: Games of T11
Post by Stig » Fri Mar 11, 2011 5:13 pm
I vote for Combat school and Amidar
Chufoglu
Re: Games of T11
Post by Chufoglu » Sun Mar 13, 2011 11:38 am
I have thought that besides me any MARP confirmer could validate/judge the games and whatever marper could report his opinions too, instead of one judge for each game. Thus, there would be more potential judges and it would result easier.
I request an editor to be confirmer to validate games of the tournament.
gameboy9 wrote: Additionally, if you don't mind an opinion about Lode Runner, if this gets selected, I wouldn't be surprised if there's a tie at 999,999 points during the tournament. If this happens, I suggest a tie-breaker of whoever gets 999,999 points first gets the higher position.
Agree.
Stig wrote:I vote for Combat school and Amidar
Sorry voting are finished, but Combat School is in the list.
Kale
Re: Games of T11
Post by Kale » Sun Mar 13, 2011 1:24 pm
gameboy9 wrote:Additionally, if you don't mind an opinion about Lode Runner, if this gets selected, I wouldn't be surprised if there's a tie at 999,999 points during the tournament. If this happens, I suggest a tie-breaker of whoever gets 999,999 points first gets the higher position.
... or maybe just score the game as most levels reached in less possible time, iirc you don't need to finish the game in order to counter stop the game, right?
1up
Re: Games of T11
Post by 1up » Thu Mar 17, 2011 6:20 am
We just played Contra over at retroleague and found that theres a bug in Contra that makes the game freeze after boss #2.
can I get to change my submission?
Chufoglu
Re: Games of T11
Post by Chufoglu » Thu Mar 17, 2011 6:37 pm
1up wrote:We just played Contra over at retroleague and found that theres a bug in Contra that makes the game freeze after boss #2.
Yes, game freeze for me also, some times
Re: Games of T11
Post by mahlemiut » Thu Mar 17, 2011 8:19 pm
Something like this? Seems to only occur when the difficulty is set to normal (default is easy)...
http://www.mametesters.org/view.php?id=3821
1up
Re: Games of T11
Post by 1up » Fri Mar 18, 2011 4:09 am
mahlemiut wrote:Something like this? Seems to only occur when the difficulty is set to normal (default is easy)...
Ive tested it on both Normal and Easy on contra.zip, contraj.zip and contra1.zip. All of them freeze if you beat the boss on your first man. Sometimes they dont for some reason? But I wouldn't recommend it for tournament play as it's frustrating not knowing if the game will freeze or not.
I will think about my new submission and post it later today
gameboy9
Re: Games of T11
Post by gameboy9 » Fri Mar 18, 2011 7:09 am
I hate to go way back in the past... but... way back in the past... January 2004 to be precise, we played Contra as a test round in the first MARP time trials. Nobody complained about Contra crashing then. They used WolfMAME 78, which was the once accepted version to use... uh... way back in the past. :)
So maybe we can play, just using WolfMAME 78 as an allowable version.
RJM
Re: Games of T11
Post by RJM » Fri Mar 18, 2011 7:32 am
The problem with Contra from memory is that the score doesn't advance until you stop firing. You need to allow the score to "catch up" before you end a stage or it will more than likely freeze. Not sure about on default settings but it happens a lot on TG settings (medium). The game CAN be finished but it's a major pain in the arse. From what I've been told this doesn't happen on the arcade machine but I don't have access to one.
Rob
DaLar
Re: Games of T11
Post by DaLar » Fri Mar 18, 2011 9:22 am
The only way I have found to *sometimes* move on to the Ice-stage, is by only shooting one shot onto the screen at a time, when the last head is close to dying (and even slower to assure that the points will be counted up!) and take caution to NOT fire again after the final shot to the last boss head..!
Have also destroyed both heads simul., granting me a pass!(?)
(All done on the first life with Normal and 50k Only, using wolf106 & 141)
1up wrote:Ive tested it on both Normal and Easy on contra.zip, contraj.zip and contra1.zip. All of them freeze if you beat the boss on your first man. Sometimes they dont for some reason?
1up
Re: Games of T11
Post by 1up » Fri Mar 18, 2011 8:16 pm
instead of Contra I will go with Shock Troopers for the Neo Geo
Re: Games of T11
Post by mahlemiut » Sun Mar 20, 2011 7:22 am
Contra freezing bug has been fixed in MAME now - apparently it was running on a 6809 as the main CPU instead of a 6309...
