[K10] Round 3 - Ghostlop [ghostlop]
sikraiken
Re: [K10] Round 3 - Ghostlop [ghostlop]
Post by sikraiken »
If Gray appears, it turns your game into an 8 stage game instead of a 7 stage game. This gives you more scoring opportunity.
wolfman24
Post by wolfman24 »
oh sorry i though it was the grey ghosts lol
wolfman24
Post by wolfman24 »
RdP
Post by RdP »
Inp don't works? 8O
BDFil, I'm having issues with one of your inps again. On the 2nd stage, the game freaks out and goes into the service mode menu - the same exact thing that happened in Cosmo Gang. I'm not sure *HOW* this is happening, but...
RdP wrote:Inp don't works? 8O
Deleted NVRAM?
Using default bios?
Made sure there are no files in the memcard subdirectory?
Haven't had a problem watching anyone else's inps so far.
BDF
Post by BDF »
That is a big problem, because i controlled everything before attacking hangon.
I also watched full inp before sending it to you and that one was working perfectly on the computer i played.
I have a new inp so i am actually watching it on another computer.
No idea where it comes from?!
Jerome
BDF
Post by BDF »
I watched my full inp (74882) on another computer and it works fine.
I do not know what to do?!
Jerome
kernzy
Post by kernzy »
screen is off centre in 106, and does not work in 148. "required files are missing".
thats me out.
good luck all!!!
:D
Barra
Post by Barra »
Blah managed 60k. Will just have to wait and see if thats enough to get through!
Andrew Barrow
BDF wrote:I watched my full inp (74882) on another computer and it works fine.
I was referring to your previous inp of 64497...
The new one plays back just fine.
Chufoglu
Post by Chufoglu »
kernzy wrote:screen is off centre in 106, and does not work in 148. "required files are missing".
thats me out.
You have to disable "stretch using hardware".
BDF
Post by BDF »
I also watched my 64497 inp on the computer i used to record it and it worked perfectly.
That is the reason why i tried my new one on another computer before sending it to you.
Jerome
thats me out.
good luck all!!!
:D
Update your Neo Geo BIOS (neogeo.zip).
Only the ghostlop ROM filenames have changed, so if your ROMs are zipped, then there is nothing to do.
As for the off-centre screen, is it the same when running in a window, as it is fullscreen?
kernzy
Post by kernzy »
hey Barry!
thanks for your help.
unfortunately, it had no effect. well, it has, now ghostlop has vanished from my list! why does it do that? happens often nowadays, when i audit all games, some go missing.
i tried street fighter, and that is still off centre.
ok, just tried running in a window and that seems to work fine.! wahey!
so i'm still in the same place. in fact, worse!! lol!
i doubt if i will compete anyway. puzzle bobble has never been on my screen, and i sucked at the other games. maybe i will not even qualify, which is embarrassing!
BBH has done me over!!! :lol: :lol:
oh, well, maybe next year.
cheers guys, and good luck!!
:D
The current Neo Geo BIOS works fine in both 0.148 and 0.106. You will get warnings in 0.106, but it will run.
sm1.sm1      WRONG CHECKSUMS:
    EXPECTED: CRC(97cf998b) SHA1(977387a7c76ef9b21d0b01fa69830e949a9a9626)
       FOUND: CRC(94416d67) SHA1(42f9d7ddd6c0931fd64226a60dc73602b2819dcf)
000-lo.lo    WRONG LENGTH (expected: 00010000 found: 00020000)
000-lo.lo    WRONG CHECKSUMS:
    EXPECTED: CRC(e09e253c) SHA1(2b1c719531dac9bb503f22644e6e4236b91e7cfc)
       FOUND: CRC(5a86cff2) SHA1(5992277debadeb64d1c1c64b0a92d9293eaf7e4a)
You can ignore these, they have no effect on playbackability. Set your frontend to view all games, not just the available ones, that should stop it from "disappearing".
