TimeTrial 2013 - R1 - Out Zone (1 loop) [outzone]
Moderator: giro-X
Re: TimeTrial 2013 - R1 - Out Zone (1 loop) [outzone]
Made over 300 tries (after two days of pattern study), still didn't come up with something satisfying my desires.
I'm going through another big session, if I don't get stage 4 completed or better I'll have to upload stage 3.
[about my team]
[my MARP profile]
[about my team]
[my MARP profile]
same here. damn hard!
Okay then, I was extending it a bit I'll use it eventually in a future uploading.RAX wrote:The method I use to calculate the framecount is from appearance of the character (blinking yellow from under the mothership) to the beginning of the explosion of the last defeated boss.
I calculated from appearance of lives and energy indicator at the top, to the appearance of STAGE XX completed. So yeah, I counted some extra frames.
36121 frames, according to the previously described method, stage 5 completed.
Very awful time for being stage 5, I didn't get speed up before almost end of stage 3 and lost my first life at stage 4 (again!).
- outzone_s5f36121_giroX.zip
- (432.4 KiB) Downloaded 679 times
[about my team]
[my MARP profile]
[about my team]
[my MARP profile]
stage 3 ok - 19246 frames if i'm correct.
- outzone-sawys-stage 3 ok-w150.zip
- (229.04 KiB) Downloaded 649 times
I tried running and finaly finished stage 3 mproving my frame number.
I also understood how to count frame by frame.
Not sure i will finished stage 4 before the end.
17162-460=16702RAX wrote:when in pause SHIFT-P advance frame-by-frame.
- bdf_outzone_428910_w150_st3.zip
- TT2013 - outzone stage 3
- (240.53 KiB) Downloaded 826 times
Jerome
Stage 3 ok - 17790
- outzone-sawys-stage 3 ok-17790-w150.zip
- (276.4 KiB) Downloaded 622 times
stage 4 ok - 28790 (473-29263)
Most stupid is die with a lot of bomb ^^
- outzone-sawys-stage 4 ok-28790-w150.zip
- (444.26 KiB) Downloaded 629 times
- franco.benedetti
- Button Masher
6th mission completed, though not that fast, about 54600 frames
Hey man, are you sure the ZIP you loaded is correct? 22 bytes only it says, it's exactly the byte dimension on an empty ZIPfranco.benedetti wrote:6th mission completed, though not that fast, about 54600 frames
Kudos for beating the sixth stage you can be of company to me there, with nii-san. The unbeatable nii-san...
39500 frames [~39910 - 461] more or less, this is because I was lazy to verify which was the first frame with boss explosion (it died with a bomb... so explosion over explosion...)
First life lost at stage 6. It was a stupid death so I expect to be playing again until I get a no miss for the first 6 stages at least. In my practice of the first two days I wasn't able to do a complete loop with no miss.
- giroX_outzone_st6_39500fr_w150.zip
- (444.2 KiB) Downloaded 859 times
[about my team]
[my MARP profile]
[about my team]
[my MARP profile]
- franco.benedetti
- Button Masher
oops...giro-X wrote:Hey man, are you sure the ZIP you loaded is correct? 22 bytes only it says, it's exactly the byte dimension on an empty ZIP
i didn't zip it cause was practicing some dk, pacman and space invaders in the meantime
in addition attachment over 512k are not allowed so:
https://www.dropbox.com/s/cbguc7fsfl1ol ... olf150.zip
that was great, mate.
is it quicker to go straight up then diagonally? seems the same to me.
never done speedruns before. if i don't shoot most of them, they turn around and shoot me!!
- CrazyKongFan
- MARP Knight
OK, I finally got thru boss 2. I thought we were counting when you started getting points, but I guess it's as soon as the boss dies. I'm not 100% sure on the frame, since I used a bomb to finish him off, but I think it's 12592. Started at 647, for a total of 11945. Gonna keep trying tonight.
- FAO-tt2013-11945-2boss.zip
- (173.82 KiB) Downloaded 649 times
I apologize for not having updated yesterday, I've been away from home. Now I'll download and replay everything new.
I will also give a final word about the reference time issue that TRB noticed (It was seen during KO too)
Finally a game where I managed to beat the 3rd boss.... definitely rusty on the game playing these days!!
Stage 03, 25617 frames.
- outzone.zip
- (326.78 KiB) Downloaded 621 times
No time to play, my son is at the hospital ...
First try today, only stage 1 clear, frames around 7700
- outzone=st1_w150.zip
- (99.44 KiB) Downloaded 793 times
