I can't upload PUZZNIC inp
Posted: Sat Jun 14, 2003 1:27 am
by sakai
I can't upload PUZZNIC inp(Over 48h).
SEVER witn porblem or other?
Upload other game (inp) same ,now? :(
Posted: Sat Jun 14, 2003 1:43 am
by zlk
The server has been down for a while. It should be working fine now. Can you login properly?
Posted: Sat Jun 14, 2003 2:17 am
by BBH
it seems that nobody can upload inps using the regular default method for the time being. You need to use the alternate form that's linked from the Submit page by uploading your zipped inps to another site and then having it point there.
Posted: Sat Jun 14, 2003 7:02 am
by Buttermaker
I upped my garoup using the default method yesterday.
Posted: Sat Jun 14, 2003 8:17 am
by diabolik
Yeah sometimes it works but most of the time it doesn't. If you don't have any other possibility to upload inps you might want to use Yahoo's Briefcase feature or some similar online file storage site, and upload your inps from there (using of course the alternative submission form like BBH said).
http://marp.retrogames.com/index.cgi?mode=fetch_url
Posted: Sun Jun 15, 2003 4:19 pm
by tar
RESULTS
got something from that URL : length 8949 bytes
That doesn't look like a .zip file...
This is what I get when using the alternate form.
http://tar.iwarp.com/zips
this is where my inps are.
They are ok, can't figure it out.
I want to send firebatl / 112750 / dos alpha69/ first place
Posted: Sun Jun 15, 2003 4:34 pm
by Buttermaker
Did you put in this exact URL: http://tar.iwarp.com/Zips/firebatl.zip ?
Posted: Mon Jun 16, 2003 10:49 am
by tar
got something from that URL : length 8957 bytes
Please be sure that the file you are giving the URL file is in PKzip format - email Zwaxy if you need help.
http://tar.iwarp.com/tar/firebatl.zip
http://tar.iwarp.com/tar/zips/firebatl.zip
http://tar.iwarp.com/zips/firebatl.zip
These are the three I have tried so far , every day actually.
I get a different length every time.
I had the same trouble last year when ztnet was not accepting uploads.
The standard form still not working either.
I should just work on some more games to send for when it is fixed.
Posted: Mon Jun 16, 2003 4:24 pm
The first two give 404s.
The third gives a 403 (Forbidden), with a message saying that data files must be on the same server as the one they are linked from. So in other words, you're screwed. :)
Posted: Wed Jun 18, 2003 11:51 am
by tar
I uploaded Demon inp. today. The regular way. Hope it isn't blocked.
Firebatl still no go. :( Ozon1 will not go (1st).
