batridrk
Posted: Thu Nov 06, 2003 9:39 am
by Abbe
Kelly's input is out of synch from the start and is not recorded with 0.62 or earlier. (Or is that bug fixed in 0.76?)
Posted: Thu Nov 06, 2003 2:09 pm
Did you check to see if he used the ASM 68k core (appears in the console)? If he is, then you'll need to use -nom68k_c_core to play it back.
Posted: Thu Nov 06, 2003 3:48 pm
by Abbe
It was recorded with the asm core enabled, but I got the same result with the c core.
Re: batridrk
Posted: Thu Nov 06, 2003 4:42 pm
by Mr. Kelly R. Flewin
Abbe wrote:Kelly's input is out of synch from the start and is not recorded with 0.62 or earlier. (Or is that bug fixed in 0.76?)
Considering the score above was recorded with Wolfmame Plus 0.71 and confirmed!, I had figured someone merely had forgotten to remove that rule and it worked fine. I even got my playback to work without a problem as well. No problem to go scouting an older version out to fix this though. It would be my fault for assuming, though was not my old recording fine?
Kelly
Re: batridrk
Posted: Thu Nov 06, 2003 4:54 pm
by Weehawk
Kelly
:lol:
Rule requires .62 or earlier, but game was introduced in .68.
"Catch 22, so 23 skiddooo...."
Posted: Thu Nov 06, 2003 4:59 pm
by QRS
It doesn´t playback for me either.
Posted: Thu Nov 06, 2003 5:20 pm
by Weehawk
Plays correctly for me after I set "m68k_c_core" to "0" in the ini file.
Posted: Thu Nov 06, 2003 5:40 pm
by Buttermaker
Weehawk wrote:Plays correctly for me after I set "m68k_c_core" to "0" in the ini file.
And after you renamed the .inp I guess. Image
Posted: Thu Nov 06, 2003 5:52 pm
by Weehawk
From #marp log:
<Buttermaker> filenames like that get changed to ******.inp
Just following your convention...
Posted: Fri Nov 07, 2003 3:10 am
YESSSSSSSSSS!!! THANK YOU!! I KNEW I WASN'T GOING INSANE! [Though I was after that retarded last death... I knew I coulda scored higher.]
Kelly
Posted: Fri Nov 07, 2003 3:49 am
by Weehawk
Kelly wrote:THANK YOU!! I KNEW I WASN'T GOING INSANE!
Whoah now...I'm not vouching for your mental health, I'm just saying the recording worked. :P
Is that a euphemism like "not playing with a full deck"?
:wink:
