Benchmarks
Re: Benchmarks
Post by mahlemiut » Sat Apr 29, 2017 4:26 am
Well, here we go. All I'll say is, MAME seems slower - especially with older drivers that don't need huge power to run.
System:
3.7GHz Core i3-6100
Intel HD Graphics 530
8GB RAM
Arch Linux (kernel 4.10.11)
WolfMAME 0.185 (SDL, 64-bit self-compiled)
Commandline options are the same as before. All values are speed percentage.
pacman      556.96
malzak      458.32
ddragon     425.57
invaders    453.07
tbyahhoo    270.49
stunrun     349.78
mrdrillr    204.53
cotton2     239.73
beastrzr    285.20
puzzloop    275.18
sfiiin      444.87
strider     498.24
rsgun       223.62
Will try with -video bgfx later, which offloads blitting to a separate thread, like the old -mt option did (only in a way that actually works properly) EDIT: scratch that idea, BGFX refuses to run faster than 60fps for some reason, so Pacman won't run faster than 99%)
LordGaz
Re: Benchmarks
Post by LordGaz » Sat Apr 29, 2017 4:22 pm
Thanks for that, Moore's law is at an end. We're still getting faster but at a slower and slower rate.
Re: Benchmarks
Post by mahlemiut » Sat Apr 29, 2017 6:51 pm
Will pull 0.126 from the old box eventually, and hope that it'll run (it should). Might give a better idea as to how much speed is lost simply through MAME shifting from C to C++14 and various emulation improvements over the past 9 years.
Re: Benchmarks
Post by mahlemiut » Sun Apr 30, 2017 4:43 am
Grabbed a 64-bit SDL WolfMAME 0.127, and oddly enough, I still get 580% on pacman. Modern OSes use up this much more CPU time? Seems weird.
EDIT: Ok, adding -nomaximize makes it run much faster. Intel must have crappy texture stretching or something.
Re: Benchmarks
Post by mahlemiut » Sun Apr 30, 2017 4:57 am
Updated to use -window -nomaximize (removes some video hardware slowness). Still 64-bit 0.185.
pacman     3999.63
malzak      541.17
ddragon     962.72
invaders   2621.93
tbyahhoo    337.64
stunrun     556.88
mrdrillr    228.16
cotton2     302.80
beastrzr    331.38
puzzloop    350.09
sfiiin      919.39
strider    1357.95
rsgun       267.01
LordGaz
Re: Benchmarks
Post by LordGaz » Sat Jan 27, 2018 10:56 am
It's that time again. Got meself an i5-8600K and naturally the first thing one does with a new system is benchmark it with MAME!
Mame now has a -bench switch so I decided to use that. From the MAME docs this is what -bench does.
-bench [n]
    Benchmark for [n] number of emulated seconds; implies the command string:
    -str [n] -video none -sound none -nothrottle
So for example you can benchmark pacman for 60 ingame seconds in the command window of your choice with:
.\mame64.exe -bench 60 pacman
Results using -bench 60.
pacman     15122%
malzak       717%
ddragon     1490%
invaders    8735%
tbyahhoo     411%
stunrun      848%
mrdrillr     281%
tekken       577%
cotton2      385%
beastrzr     450%
puzzloop     450%
sfiiin      1637%
galaga      5681%
strider     2866%
rsgun       355%
Obviously you can't relate these results exactly to previous because it doesn't test video and I decided to run each for 60 secs so they go deeper into the game but at least we can benchmark on the same playing field.
