arcadecl-mc2
Posted: Thu Jul 08, 2004 2:29 am
by Weehawk
Posted: Thu Jul 08, 2004 6:36 am
by destructor
For me playback correctly only first 2 stages, next desync.
Posted: Fri Jul 09, 2004 3:20 pm
third zero.
Posted: Sat Jul 10, 2004 9:41 am
by Gerhard S
i play this game with mame32plus0.80 (wolfmame80)
i use the default settings (bonus town every 12000)
the playback-funktion have an error
the aufzeichnung funktioniert nicht richtig - bei allen missile command ist der gleiche fehler
wenn ihr mir nicht glaubt dann last es halt
gruß
gerhard (germax)
Posted: Sat Jul 10, 2004 2:17 pm
unfortunatley when 3 people can't play your recording back (default settings expected) then your score is zeroed, no question. THe only thing that can reinstate your score is if two people other than yourself can claim to play it back with defined settings, you may not change your previous score back UNTIL then.
I have a feeling you must record with No frameskip set in your wolfmame32 settings, that can sometimes cause playback problems with analogue games.
recording zereoed again.
Posted: Sat Jul 10, 2004 6:57 pm
by Gerhard S
Chad wrote:unfortunatley when 3 people can't play your recording back (default settings expected) then your score is zeroed, no question. THe only thing that can reinstate your score is if two people other than yourself can claim to play it back with defined settings, you may not change your previous score back UNTIL then.
no ploblem - i play this game again - and i hope the playback works fine
