An advice to Hotrod PS/2 -controller owners
Re: An advice to Hotrod PS/2 -controller owners
Post by BeeJay » Sun Jul 27, 2014 6:40 pm
Installed the x-arcade conversion kit into my HotRod SE over the weekend and it works like a charm. Plugs into the USB port, and no longer needs a keyboard connected etc. The kit also came with 2 x spare micro-switches, which you can use to fix any broken/worn joystick or button micro-switches. Nice! :)
It was clearly the keyboard encoder in my HotRod SE that was causing problems with some button/joystick contentions not the joystick/button hardware as everything now works correctly, without the issue with left/right movement getting "paused" by pressing the main fire button. I was expecting to need to replace some of the micro-switches!!
Unfortunately this does now make it much harder to justify buying a new controller... :(
Post by The TJT » Fri Aug 01, 2014 3:22 am
Thanks for the info Beejay.
=D>
