MARP Confirm Automation 0.1.2.2 released!
walbeehm
Re: RE
Post by walbeehm »
QRS wrote:ohh come on guys.. Ron has done a neat little application here that might help the confirming etc, and all you are doing is telling him he uses the wrong programming language?
I got dragged in this discussion against my will to start with. :wink:
But I'm not attacking him in any way. Useful things CAN be written in VB.
And I haven't even tried his program yet.
Hmm... wait a minute... I don't think I even mentioned VB in this thread. Maybe I should just shut up now. :wink:
Ben Jos.
Ben Jos Walbeehm
roncli
Post by roncli »
You have now. ;)
-roncli
Re: RE
QRS wrote:Of course VB is easier to use and more limited that c or c++, but why compicate things when you want to create a simple aplication?
There's always those people that say that binary is the only real language.
I think the main problem here is needing the .NET framework to use the app, which, in my opinion at least, is probably overkill.
roncli
Post by roncli »
A bug has popped up... If you are using two or more network identities (in other words, you get two or more IP addresses when you run ipconfig), it may grab the wrong IP that is not connected to the Internet. :( I am looking into a way to resolve this problem.
-roncli
seymour
Site Admin
Post by seymour »
roncli wrote:A bug has popped up... If you are using two or more network identities (in other words, you get two or more IP addresses when you run ipconfig), it may grab the wrong IP that is not connected to the Internet. :( I am looking into a way to resolve this problem.
Add an option to use a specified IP address? It definitely wouldn't pick up my real IP, since my system doesn't know anything about it, just it's LAN IP.
Of course, I refuse to install the .NET Framework, so I won't be able to run your program anyway.
Chris Gushue
MARP IRC/Forum Maintainer
http://gushue.net
roncli
Post by roncli »
Then shush. :P
It doesn't need to pick up a "real" IP, it just needs to pick one up that goes out to the Internet. For example, my home computer is 10.1.0.2, and works just fine.
-roncli
roncli
Post by roncli »
0.1.2.2 released.
-roncli
