The official awesome replay thread
- tmorrow
- Button Masher
Interesting. Where does it specify what those correct settings are? I've never touched either the BIOS or 68K core settings in any replay ever. Most replay work for me. Thanks for the help.mahlemiut wrote:Worked perfectly for me in MAME Plus 0.80u1.
Make sure you have the correct BIOS settings and 68K core settings, although I don't remember specifically setting the BIOS used.
And make sure you have plenty of popcorn, this is one looooooong recording.
http://www.ga-la.com/replay/view.asp?id=2552
Samurai Shodown II
550,190
All clear, using Hanzo.
Kawaks 1.45
http://www.ga-la.com/replay/view.asp?id=2543
Snow Bros. - Nick & Tom (set 1)
5.49 million
All clear, 1 miss.
MAME 0.90
Samurai Shodown II
550,190
Kawaks 1.45
5.49 million
All clear, 1 miss.
MAME 0.90
I found the attached Track and Field recording on a Russian emulation site. Its by a player called "Artifice", and scores 101,800 on the first cycle (using included NVRAM). It plays back without NVRAM also, but only to 100,800 since it loses a 1K bonus on the long jump. Its WolfMAME95.
And I checked the INP and he doesn't use the Run Like Hell (RLH) cheat.
-gastrainga
-gastrainga
- fak_trackfld_101800_wolf95.zip
- (23.97 KiB) Downloaded 498 times
I thought you concluded in your analysis that 98k was probably not legitimately possible. What do you think the explanation is?
Also, odd that someone was familiar with WolfMAME but would not submit to MARP.
Were there any other details on the site? Link?
And situations like this make me certain that someday we will have a dispute over ownership of a recording. It's just a matter of time.
try enabling NVRAM when you play it backWeehawk wrote:I thought you concluded in your analysis that 98k was probably not legitimately possible. What do you think the explanation is?
I probably won't be playing it back any time soon, I was just going by George's comments.BBH wrote:try enabling NVRAM when you play it backWeehawk wrote:I thought you concluded in your analysis that 98k was probably not legitimately possible. What do you think the explanation is?
No idea what you're hinting at...
My Japanese is non-existent! Does anyone know how to download this snowbro2 recording?mahlemiut wrote: http://www.ga-la.com/replay/view.asp?id=2543
5.49 million
All clear, 1 miss.
MAME 0.90
http://www4.emu-zone.org/corner/view.asp?id=2612
Strikers 1945 III / Strikers 1999
3,433,900
All clear, no miss, no bomb, max chain = 135
MAME Plus 0.62~0.71
And ignore the description and filename, the inp inside the zip is correct. The player seems to have confused it with another inp.
3,433,900
MAME Plus 0.62~0.71
george.inp MOST LIKELY IS USING AUTOFIRE or SLOWDOWN!!!
-------- End Of analinp Report --------- Attachments
- 9,74
- leprechaun.PNG (15 KiB) Viewed 19952 times
In case anybody hadn't figured it out yet, the explanation is that the INP is a fake that I made while investigating the highest possible scores on Track and Field in this forum thread over at TG http://www.twingalaxies.com/forums/view ... 3&start=30Weehawk wrote:I thought you concluded in your analysis that 98k was probably not legitimately possible. What do you think the explanation is?
I figured I'd left enough hints in that it was a fake that everybody would figure it out pretty easily. I made the INP programatically by inserting button pushes by hand using trial and error to find the best results for each event. The running is the same as you would get with autofire, but the timing on everything is better than you could get in real-life even with auto-fire since I made all the timing (jumps, angles, throws, starts), frame "perfect". If anybody can beat any of the individual event scores, I'd like to see the INP for it (even if you use auto-fire, but not RLH cheat. I know High Jump can go higher with RLH). I think some of them can be improved just a bit.
And don't worry, MARP editors would have easily detected this as a fake even if I hadn't left in hints.
Yes, NVRAM was edited by hand. I put these in for fun just to make knowledgable people wonder if they were real. I couldn't get over 9.72.The TJT wrote: What's with 9,74 and 73...I thought you said that couldn't get over 9,72 even with over 1500 speed. Hand edited nvram?
-George
G.T recorded a 2-all Mazinger Z replay:
http://www5f.biglobe.ne.jp/~zekzek/repl ... ayh_r.html
http://cgi.www5f.biglobe.ne.jp/~zekzek/ ... me.cgi?385
This replay only works with mameplus 99. It would not work for me with wolf99 or mame32-99.
