Posted: Sat Dec 23, 2006 6:39 pm
Settings are changed in Test Mode from memory. Default extends are 50k and 200k only, I think.
Yes. that's right.mahlemiut wrote:My guess is 100k x lives remaining.LN2 wrote:that is truly masterful level of play for the game if played legit(no save states used, or pausing etc.)...although the leeching gets semi-borderline at spots. It was still awesome to see the game actually has an end with apparently a 2.2 million bonus given at the end(?). 2.2 million? that is an odd number.Weehawk wrote:http://marp.retrogames.com/inp/noo_romp ... mame60.zip
Kill many enemies at time when you use the smallest board.LN2 wrote:oh, that sounds very possible....means those 1-up combos he got along the way are very valuable.
I didn't think he got that many though....would have to watch it and count them up.
how often are extra men awarded? I see no settings are accessible for the game....odd.
http://greenwoods.ld.infoseek.co.jp/1up/1up.htmlLN2 wrote:yep novice, I had gathered all of that information from playing it myself.
I agree..to do what that replay shows is likely mostly entirely patterns. I suspect for that replay that save states were used between stages or pausing used to review a pattern for the next stage. Yes, with a lot of play, you can get where you know them all...but the playback fps shows as 3.3...so it's likely a connected inp or gameplay with a lot of pausing.
most of my play is patterns or at least semi-patterns where I have a start to the board. my patterns currently are just getting through the boards though. I figure little point to doing more until you can get to the end of the game.
although as I keep playing it I am revising my patterns bit by bit to get more of the gems and/or improve time or get a few more enemies squashed.
I will figure these out on my own. I hope for t10 someone doesn't just copy the patterns from that inp to set a score. almost anyone can do that.
You're basing all this on the fps being 3.3 when you exited out??LN2 wrote:I agree..to do what that replay shows is likely mostly entirely patterns. I suspect for that replay that save states were used between stages or pausing used to review a pattern for the next stage. Yes, with a lot of play, you can get where you know them all...but the playback fps shows as 3.3...so it's likely a connected inp or gameplay with a lot of pausing.
I agree.BBH wrote: Hisa said NOO is the Gamest record holder, so his skill has already been proven. Why would he cheat for MARP?
I've met some Nobel Prize winner's and I'm not so sure they wouldn't have cheated on their elementary school examininations. They wouldn't have needed to, but it doesn't mean they wouldn't have.Novice wrote:I agree.BBH wrote: Hisa said NOO is the Gamest record holder, so his skill has already been proven. Why would he cheat for MARP?
Novel Prise winner never cheat at elementary scool examination.
lol. you are right!Zhorik wrote: I've met some Nobel Prize winner's and I'm not so sure they wouldn't have cheated on their elementary school examininations. They wouldn't have needed to, but it doesn't mean they wouldn't have.
yes. I agree.Zhorik wrote: Regardless, NOO's GAMEST record is over 11M, and I don't think he used save states to put up his score of just under 5M (which would have been maybe 7.9M if he'd leeche all his 22 extra men on the last level). If he'd used save states, why would he have left the deaths in? I think he's just really, really, really good.
Novice wrote: "can not" is always do not.
but "would not have need to" is not always do not.
Yoda wrote:No. Try not. Do... or do not. There is no try
hmm, so using F10 would interfere with this? how? you figure it would show higher fps then if #frames/time to show.BBH wrote: The 3.3 you're seeing is your own average FPS, most likely caused by using frameskip and F10. It has nothing to do with NOO.jp's recording.
well, why is that inp in deleted status?Why would he cheat for MARP?
Average FPS: 114.591500 (1993 frames)LN2 wrote:hmm, so using F10 would interfere with this? how? you figure it would show higher fps then if #frames/time to show.BBH wrote: The 3.3 you're seeing is your own average FPS, most likely caused by using frameskip and F10. It has nothing to do with NOO.jp's recording.
With F10 pressed, my system was showing the playback at several times regular speed.
In those cases, you'll need to quit before playback reaches the end of the inp. It's an issue that cropped up when MAMEdev started closing the inp at the end of playback, and nullifying it, stopping detection of whether you're using an inp or not.Chad wrote:when you use -playback the fps reported is the fps of the mame program when you are using it not when it was recorded, so if you were pausing during the playback it would report below 60 or if your throttle was off it would be higher than 60 (60 or the default fps of the game). Some wolfmame's around 101 don't report the speed percentage at the end anymore, just fps of the current session, i think that's just a miss during the wolfmame rework.
LN2 wrote:well, why is that inp in deleted status?
Novice wrote:I do not know everything.Buttermaker wrote:What players deleted their recordings?Novice wrote:Current MARP has very few uploads which worth to download and see.
at least I can find only two recordings. (marble madness and makai densetsu)
Why?
THERE IS THE MAN OF SCOURGE.
In spite of applyed enough informations and knowledge,
"THE MAN who has worthless biased opinion with poor skill" guy attack unseen tricks which he can not do it by himself to defend his LB points.
He success to defend his LB points.
by complain not skill.
it was enough to be disappointed all other players.
Many very good players delete all recordings from MARP.
Team2ch's stop to upload unseen skill any more.
I do not know "HE" is worthy player or not.
but I certain MARP lost many good players and good plays.
because all we love to see the skill. not ignorant asshole's worthless comment.
I feel MARP become boring place. very good replayers are gathering other place now.
The reason "why MARP does not have any troubles for several month",
it is very simple. there are no worthy replay. no trouble. no wonder.
the result of this poll says "MANY MARPERS KNOW THE FACT."
but many "Quality over Quantity style player" removed all theirs.
especially "burning force" and "rompers" top was gamest record holder of those games.
disappoints this type of player is enough to be called as "scourge".
