Vampire Savior 2 - Trick that can happen if you use the '?'
Posted: Mon Jan 05, 2004 9:35 pm
When you start a game do this:
- Go to the '?'
- Press the key '1' 5 times (use the key '2' if you are using player 2).
- Use a punch or kick to select your player.
If you have done this OK, a shadow appears behind your fighter. -see image-
When you win a fight, The shadow goes to the loser. (and you continue with a different fighter).
http://perso.wanadoo.es/terminator_ii/s ... wolf78.zip
PD: This trick works in Vampire Savior 1 and Vampire Hunter 2 (and clones)
- Go to the '?'
