Hi<p>
Just setup my Arcade X Joystick but something really strange is happening??
If I run a game the default keys in MAME are set to the arrow keys, I have to go into each game and change the settings to use the arrow keys on the numeric keypad??
So the up,down,left,right show up as NUM2, NUM8 etc etc....
Sometimes when I press an arrow key on the number keypad it displays as say 'Right Arrow' ??
It's all a bit strange as I know that the normal default position keys (Arrows) should just work....
Wondering if my keyboard is not setup right?
Any help would b great...
Thanks
Darren
aka Game Guru
virtualinsanity@blueyonder.co.uk
X Arcade Joystick Question
the hotrod setup uses the numpad you might try setting hotrod=yes or
hotrodse=yes in mame.cfg (note i'm going by memory on the switch
names) but then the fire buttons might be different...
churritz@crash.cts.com
Joe Ledesma
I'm not 100% sure, but I believe what is occuring with the NUM/arrow
keys is an issue with the NUM lock. Mess around with it.
JoeyL21988@yahoo.com
