Page 1 of 2
				Tapper
				Posted: Sun Jun 30, 2002 4:33 pm
				by kfx
				I can´t get this to playback, it gives a sound error when I try to play it in m35b11 dos and it get´s out of synch when I try it in MAME32
http://marp.retrogames.com/inp/sls_tapp ... m35b11.zip
				Posted: Sun Jun 30, 2002 7:09 pm
				sound appears to be broken in that mame version for this game, and the nvram issue started (i think in the late 35 cycle).  This game requires a default nvram file and Does playback correctly for me using dos mame 35b11 (sound on even though it doesn't work) and with default cfg/nvram files existing.
nvram requiring recordings were grandfathered before sep 15.2001, all other recordings uploaded after that will be dqued if nvram files are required to play them back.
on a side note the easter egg recording
http://marp.retrogames.com/inp/waf_tapper_0_m35b5.zip
i could not get to playback.  but i also don't know what i'm looking for, the inp doesn't appear to drop a credit.
				Can´t playback Russ La Croix tappera recording
				Posted: Wed Jul 03, 2002 6:06 pm
				by kfx
				I can´t get this to work at all, anybody with more luck then me?
http://marp.retrogames.com/inp/rwl_tapp ... mame55.zip
				Posted: Thu Jul 04, 2002 2:21 am
this one works with dos mame no sound and with a default nvram file, it's better than zereod.
				Posted: Sun Jul 07, 2002 2:09 am
				by roncli
				Can´t be nvram
				Posted: Sun Jul 07, 2002 5:34 am
				by kfx
				I use the record.bat file from MARP when I make a recording, so it can´t be a nvram issue.
				Posted: Sun Jul 07, 2002 5:49 am
				by kfx
				Just tested them again, I can get them to playback in both dos and windows command line version.
The last Tapper scores I got confirmed said that they could only be playbacked in dos. So maybe that´s it?
				Posted: Sun Jul 07, 2002 7:15 am
				by roncli
				Well, that's rather lame.  I can run the DOS version, but it totally messes up my computer when I finish the playback and go back to Windows XP.
				Posted: Sun Jul 07, 2002 7:22 am
				by roncli
				Crap... I tried that, and now it doesn't even register the one player start (although it registers the coin).  Someone else'll have to confirm those then.  Sorry!
				Posted: Sun Jul 07, 2002 3:39 pm
all three of these work perfectly using dosmame60 or CLI mame60 and sound and this mame cfg file and with my win98se boot.
				Posted: Wed Jul 17, 2002 3:10 am
				by roncli
				http://marp.retrogames.com/inp/kfx_tapp ... mame61.zip
Using the provided .cfg file, I was unable to playback any, including this new one.
				Posted: Wed Jul 17, 2002 4:07 am
				this one didn't work in XP but i'm sure it would work in win98se. what oses do you have roncli?
				Posted: Wed Jul 17, 2002 7:10 am
				by Frankie
				Chad wrote:this one didn't work in XP but i'm sure it would work in win98se. what oses do you have roncli?
I confirmed his 3 tapper scores a while back. They could only playback on DMAME with sound. That is probably also the case with this one.
I use Windows 98.
				Posted: Wed Jul 17, 2002 1:50 pm
				by roncli
				Yah, I use XP.
Why are there compatibility issues between OS'es?  That doesn't make sense.  We should prolly write mametesters about this one.
				Posted: Wed Jul 17, 2002 2:08 pm
				yeah oses plenny, even with cli mame, some games don't playback using the same mame.exe on different operating systems.  it doesn't make sense but it's the brutal truth.
