Hi. if anyone out there can post an .inp file of the 255 lives trick in Mr.Do!
using x-mame .102 or macmame equivalent i would greatly appreciate it.
am currently running macmame 066.2 but will ugrade to newer version if .inp file requested becomes available. thanking you all in advance.
am looking for an .inp file
- destructor
- MARPaholic
Did you tried this:
BANNED TECHNIQUE : 255 lives (it's possible to win 255 lives on the first screen, but only if an apple appears in the top two rows of the playfield ; begin by digging a tunnel directly from the bottom of the screen to just below the apple, but leave enough dirt under it that it doesn't fall ; next, kill all of the enemies but one, then lose all of your extra lives ; as soon as you're on your last life, go right under the apple and wait ; eventually, the remaining enemy will come after you ; allow the apple to drop, but, in the interval before you're squashed, kill the enemy with the powerball ; if all has gone well, you'll be carried to the bottom of the screen, the music will go haywire for a moment, and you'll be awarded 255 extra lives)
- Button Slapper
yes
hi. thanks for reply. I have tried this many times on the Taito version of macmame. i don't know if it's my timing or game settings, or trying the wrong apple but I can't make it work. if i had a video to see it would probably help. cheers
Go here: http://marp.retrogames.com/weird.htm
or click on 'Index' (on menu at top of screen) and then Weird Things, and search for mrdo - you'll find the trick 2nd from the bottom of the list.
Kranser.
Kranser.
- Button Slapper
not compatible
hi mate. thanks. .inp file was created on wolfmame .83. i've learned i can't view the .inp because i'm using macmame. need .inp for macmame.cheers
andy.
andy.
- Button Slapper
FINALLY!
i finally managed to succeed the 255 lives trick for Mr.Do. thanks to all whom have tried to help me out with us. will try again and post an .inp if anyone is interested. thanks again.....again.
