Space Invasion
Space Invasion
http://marp.retrogames.com/r/invasion
http://marp.retrogames.com/inp/9/e/3/gj ... lf87u1.zip
Can't playback this 30000 but wrx2's works fine. Tar any help? I've tried both 87u1 versions, and it starts with multiple credits entered with no start button pushed.
http://wolfmame.marpirc.net/wolfmameplus-087u1-gcc.zip
http://wolfmame.marpirc.net/wolfmameplus-087u1-vc.zip
it works here.
.inp size is 13,000
i use a 3.2 gigahertz
AMD sempron processor
windows xp
a couple of screen captures
last ship
last ship
at 10k
at 10k
can you zip up your wolf87u1.exe and dll and then open in winzip and tell me what the "CRC" or 'CRC-32' collumn says. I want to see if there is a wolf87u1 that i don't have.
[root@genie tmp]# unzip -v /mnt/d/mame/playback/wolf87u1.zip
Archive:  /mnt/d/mame/playback/wolf87u1.zip
 Length   Method    Size  Ratio   Date   Time   CRC-32    Name
 7080960  Defl:X  6887427   3%  10-14-04 22:41  6de9a250  mamep87u1vclib.dll
  196608  Defl:X    49624  75%  10-14-04 22:42  cc8e3618  mame32.exe
   26624  Defl:X    13685  49%  10-14-04 22:42  b64feaa8  wolf87u1.exe
 7304192          6950736   5%                            3 files
[root@genie tmp]# unzip -v /mnt/d/mame/playback/wolf87u1.gcc.zip
Archive:  /mnt/d/mame/playback/wolf87u1.gcc.zip
  415232  Defl:N   144905  65%  09-30-04 21:50  626512f8  mame32.exe
 6962688  Defl:X  6844254   2%  09-30-04 21:50  e1edb0ce  mamep87u1lib.dll
   10240  Defl:N     3091  70%  09-30-04 21:50  15e5dd15  wolf87u1.exe
 7388160          6992250   5%                            3 files
ok,
i grouped the 3 files up
into a zip and then looked at
them as you pictured above...
then i took a picture of it using the
Prt scr
SysRq
button on the keyboard.
Now , where is the pic located?
my brother showed me once.
Some place on the start menu.
thanks, don't need to send picture, just say if the crc columns of the three files are the same, that would indicate something other than a wolfmame version.
mame32p87u.exe..........9/30/2004 9:50 pm.....415,232........626512f8
mamep87u1.exe............9/30/2004 9:50 pm.....10,240.........15e5dd15
mamep87u1lib.dll...........9:30/20049:50pm......6,962,688......e1edb0ce
crc in last listing
gracias that puts your version as the gcc version, now to ascertain why i can't still play it back with this version....
tar wrote:ok,
Prt scr
SysRq
Actually it is now in your clipboard ready to be pasted into a program capable of displaying it. Try opening MS Paint and then use the edit/paste menu. You should now see your picture and can save it somewhere on your computers HDD. :)
kernzy
Re: Space Invasion
Post by kernzy »
i have both 87-gcc and 87u1-gcc, i had to add folders/files myself, i cannot get either of them to work, even though i have a good working copy of 83u1.
am i missing something?
Re: Space Invasion
I watched lord gaz's 40k space invaders using wolf88
I viewed you color invaders .inp using wolf 106
both playback to the right amounts
kernzy
Re: Space Invasion
Post by kernzy »
yes?
Re: Space Invasion
my point is that you listed the 40k sisv game as being for wolf149,
it works for wolf106 instead.
an edit is needed in order to be correct
kernzy
Re: Space Invasion
Post by kernzy »
aaaahh!
sorry, my mistake.
