Wow Fantasia
Wow Fantasia
http://replay.marpirc.net/r/wownfant
http://replay.marpirc.net/inp/1/a/f/ter ... olf138.zip
other recordings playback but top recording starts out ok in africa but doesn't finish first level.
- Massimo Gaspari
- Button Masher
Re: Wow Fantasia
Also in inp me does not work. The game ends in round 1.
- Massimo Gaspari
- Button Masher
Re: Wow Fantasia
I recorded a lot and I checked. The result is ok.
Someone can try please? Thank you.
- Button Masher
Re: Wow Fantasia
i got to 119800 with two caveats... using 139 and throttling, cuz i was so sick of this slow-ass game. suppose that doesn't count for much. will try and take a more serious look later
Re: Wow Fantasia
Massimo, i also get 119k like QCN. Which specific recording are you refering to that you believe playsback ok?
- Massimo Gaspari
- Button Masher
Re: Wow Fantasia
I do not understand ... I focused on my game and after the bonus 119,800 points is no longer I play, I did those two deaths to 119,800.
When I reviewed the game last time I was not killed in that round and I finished 4 more rounds before ending at 192,500.
I apologize for the problem, try again to record another inp with the new wolfmame 139 instead of 138.
It may be possible that the damaged zip file?
Thanks for your control.
Re: Wow Fantasia
thanks for checking this and confirming it! It is probably most likely an inp bug in mame. the zip corruption we could detect by crc. Another version is worth a try either higher or lower, but understand the bug may not have been fixed and we might still see it. Most definitely, make sure "frameskip" is set to 0, but i think you already know this. good luck!
- Massimo Gaspari
- Button Masher
Re: Wow Fantasia
I made another batch.
I used the last 139 wolfmame with this commandline:
mame.exe wownfant.zip -record wownfant.inp -frameskip 0
I then checked the replay on two different PCs running Windows XP with this commandline:
mame.exe wownfant.zip -playback wownfant.inp
The end result is 286.100 and the inp time is 24:46:51
These scores of deaths during the game:
14.900 - 54.100 - 65.200 - 213.400 - 213.500 - 255.600 - 266.000 - 286.100
I hope that this time you will be able to validate it.
Thank you and sorry for the inconvenience.
- MassimoGaspari@AIVA_wownfant_286100_wolf139.zip
- (232.65 KiB) Downloaded 187 times
Re: Wow Fantasia
wow, we have a winner, plays back fine! i don't think mame fixed anything in 139 but at least it worked that time.
- Massimo Gaspari
- Button Masher
Re: Wow Fantasia
Thanks for confirmation.
I'm sorry I made you lose time with the previous INP.
I'm glad that now is ok.
