To help speed up your time, jumping is a little bit faster than walking, so keep that in mind as you go through each segment.
You need to complete one stage to move on to game 2, but you can only complete four stages before I consider the game completed for this round. I will count substages as well as stages completed for this round. A completed substage basically is the result of a mini-cut scene, which is something to the effect of the "hero" doing one of those medieval victory stances, the screen fading out, then back in to the next substage. There are two substages in stages 1, 2, and 4, but there are four substages in stage 3.
Timing will be calculated by taking the time used to complete each stage AS GIVEN BY THE GAME. That makes it easy on everybody and you don't have to try to fly by the end-of-stage scoring... unless you want to.
GAME: Knights Of The Round (World 911127) (1991)
GENRE: Fighting
DIR: knights
REQUIRED VERSION: 99 or 106
SCORING: xymmss, x = stages completed, y = IF YOU LOSE BEFORE STAGE 4, substages completed IN THE STAGE LOST, m = 59 - minutes used, s = 59 - seconds used - USE TIME GIVEN FROM THE GAME AT THE END OF EACH STAGE and add each time together.
MINIMUM: 1 full stage completed
MAXIMUM: 4 full stages completed
GAME TO SUBMIT TO: *tt2-game1
Let me know if you have questions or you don't think I said what I was aiming for correctly. Good luck to all!
Click here to see current leaderboard
Click here to see time remaining - Round ends Jan 16 2011 @ 23:59:59 GMT
---------------------------------------------- QUALIFIED PLUS TIME BONUSES
01. +90 sec - COMPLETE - 12:02 - El_Fumador
02. +60 sec - COMPLETE - 16:37 - DaLar
03. +45 sec - 3 stages + 1 substage - 09:42 - Giro-X
04. +30 sec - 3 stages + 1 substage - 13:22 - Innuendo
05. +25 sec - 2 stages + 3 substages - 03:24 - JCK
06. +20 sec - 2 stages + 3 substages - 03:27 - Rax
07. +15 sec - 2 stages + 3 substages - 04:00 - Potante
08. +12 sec - 2 stages + 3 substages - 04:31 - Sawys
09. +10 sec - 2 stages + 3 substages - 04:36 - Marco Marocco
10. +08 sec - 2 stages + 1 substage - 03:41 - Chronos256
11. +06 sec - 2 stages + 1 substage - 03:59 - TheBSM
12. +05 sec - 2 stages + 1 substage - 04:43 - Agodzilla
XX. +04 sec - 2 stages + 1 substage - 05:12 - Gameboy9
13. +04 sec - 2 stages + 1 substage - 05:13 - MassimoGaspari
14. +03 sec - 2 stages + 1 substage - 05:52 - 1up
15. +02 sec - 1 stage + 1 substage - 01:57 - CrazyKongFan
16. +01 sec - 1 stage + 0 substages - 01:32 - Phil Lamat
Underlined scores are unconfirmed.
Red scores indicate scores that is different than claimed. (should be explained in a reply to this thread)
Grey score is coordinator's score, which doesn't count since he's ineligible to win.
