SOKOBAN
SOKOBAN
Post by Phil Lamat » Fri Jan 13, 2006 11:35 am
Some of you already know, I'm found of this wonderful puzzle game.
Maybe you will be interested (at least Skito, who had developed a solver if I remember correctly) by a new site for which I had collaborated :
http://sokobano.de/
It (normally) detects the language you're using ; 3 languages supported :
english-german-french (I've done all the french part).
If you click on "levels", you access to a list of a lot of collections with plenty levels to play.
You can find tables with all world records.
The main interest of this site is -like on Marp !- that you can upload your hiscores on each level, and also get upload notifs by mail.
Cool, no?
Post by Chad » Fri Jan 13, 2006 12:31 pm
very cool! This could become addicting to certain people :)
one page isn't in english yet :) if someone can first pass translate it i'll clean up the gramar, if it's not already done in a hidden link.
http://sokobano.pytalhost.de/en/games.php
Post by Phil Lamat » Fri Jan 13, 2006 8:34 pm
Thanks to point this page ; for translation, see my private mail.
I forgot to tell : if you want to upload some solutions, do it in LURD format (Left-Up-Right-Down) which is used by 99% of players and programs.
I hope you will be able to improve some ; you will see that I have already entered a lot :wink:
dan
Re: SOKOBAN
Post by dan » Sun Mar 25, 2012 2:39 pm
Re: SOKOBAN
Post by Phil Lamat » Sun Mar 25, 2012 3:33 pm
Hi Dan ...
Click on the level where you want to submit a solution.
Then you've 3 boxes : 1 for your (nick)name, 1 for your mail, and 1 called "submit" where you can copy/past your solution.
Note that you must use the LURD format for the solution (this format is the most used in Sokoban games).
L=left, U=up, R=right, D=down
Note that I'm still involved in this great game, I even run a monthly competition :
http://perso.numericable.fr/plamat/soko ... cores.html
(this month we're searching on a 30 levels set by Marcus Palstra, very hard set from an author living in ... Bolivia !)
dan
Re: SOKOBAN
Post by dan » Mon Mar 26, 2012 8:46 am
Thanks Phil!
But, I was making the mistake at the time of creation of a map.
It caused the submitt error. #-o
Re: SOKOBAN
Post by Phil Lamat » Mon Mar 26, 2012 9:02 am
Note that if you plan to take 1st place on Marp games (boxyboy/soukobdx) it's a very disappointing scoring : you don't take bonus points from optimizing moves, but only for walking !
so the hiscore will show leeching, with the pusher walking and walking on empty till he stays under best steps ...
To resume, I know how to take the high score on that, but don't bother to do it as it is annoying
dan
Re: SOKOBAN
Post by dan » Mon Mar 26, 2012 10:57 am
Phil Lamat wrote:Note that if you plan to take 1st place on Marp games (boxyboy/soukobdx) it's a very disappointing scoring : you don't take bonus points from optimizing moves, but only for walking !
Of course, I understand it and also know how to score infinitely.
I am not aiming at the Marp top.
It is my individual interest simply.
Re: SOKOBAN
Post by Phil Lamat » Mon Mar 26, 2012 11:04 am
dan wrote: It is my individual interest simply.
I understand.
Sokoban is a great game
Re: SOKOBAN
Post by Chad » Mon Mar 26, 2012 7:59 pm
dan wrote:Thanks Phil!
Phil, did you see this? It happened a few minutes before your reply, it sounds like Dan is having trouble with uploading regular sokobon scores with a new map (NOT on marp).
Re: SOKOBAN
Post by Phil Lamat » Tue Mar 27, 2012 8:04 am
I don't understand clearly what is the problem ?
if the LURD is rejected with an error message, it means that your solution is for a level which doesn't match exactly with original level from Sokobano site
(some levels have several versions, with slight differences, like 1 wall removed, or position of pusher changed at the beginning)
If it can help, you can retrieve a level from your LURD solution there :
http://sokoban.online.fr/tools/page_analyser.html
Just put your solution, and the level appears ; you can compare with level on Sokobano site
dan
Re: SOKOBAN
Post by dan » Wed Mar 28, 2012 6:13 am
Do you have it turned into trouble by what I said?
I had to play Sokoban Deluxe recently with the Sokoban++.
I entered the map myself.
I think that was to update the number of steps, I was mistaken because there was a mistake on the map.
