berzerk
Re: berzerk : kernzy
heres what my configuration folder contains...:
# CORE CONFIGURATION OPTIONS
readconfig 1
writeconfig 0
# CORE SEARCH PATH OPTIONS
rompath roms
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath .;ini
fontpath .
cheatpath cheat
crosshairpath crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory cfg
nvram_directory nvram
memcard_directory memcard
input_directory inp
state_directory sta
snapshot_directory snap
diff_directory diff
comment_directory comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave 0
playback
record
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
burnin 0
# CORE PERFORMANCE OPTIONS
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
sleep 1
speed 1.0
refreshspeed 0
# CORE ROTATION OPTIONS
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
# CORE ARTWORK OPTIONS
artwork_crop 0
use_backdrops 1
use_overlays 1
use_bezels 1
use_cpanels 1
use_marquees 1
# CORE SCREEN OPTIONS
brightness 1.0
contrast 1.0
gamma 1.0
pause_brightness 0.65
effect none
# CORE VECTOR OPTIONS
antialias 1
beam 1.0
flicker 0
# CORE SOUND OPTIONS
sound 1
samplerate 48000
samples 1
volume 0
# CORE INPUT OPTIONS
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
ui_active 0
offscreen_reload 0
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
natural 0
joystick_contradictory 0
coin_impulse 0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
positional_device keyboard
mouse_device mouse
# CORE DEBUGGING OPTIONS
log 0
verbose 0
update_in_pause 0
debug 0
debugscript
debug_internal 0
# CORE MISC OPTIONS
bios
cheat 0
skip_gameinfo 0
uifont default
ramsize
confirm_quit 0
ui_mouse 0
inpview
inplayout
# WINDOWS DEBUGGING OPTIONS
oslog 0
watchdog 0
debugger_font "Lucida Console"
debugger_font_size 9
# WINDOWS PERFORMANCE OPTIONS
priority 0
multithreading 0
numprocessors auto
profile 0
bench 0
# WINDOWS VIDEO OPTIONS
video d3d
numscreens 1
window 0
maximize 1
keepaspect 1
prescale 1
waitvsync 0
syncrefresh 0
menu 0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 1
# DIRECT3D-SPECIFIC OPTIONS
d3dversion 9
filter 1
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 0
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 2048
hlsl_snap_height 1536
shadow_mask_alpha 0.0
shadow_mask_x_count 320
shadow_mask_y_count 240
shadow_mask_usize 0.09375
shadow_mask_vsize 0.109375
curvature 0.0
pincushion 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 0.7
scanline_bright_scale 1.0
scanline_bright_offset 0.0
scanline_jitter 0.0
defocus 0.0,0.0
converge_x 0.0,0.0,0.0
converge_y 0.0,0.0,0.0
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
phosphor_life 0.0,0.0,0.0
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
# PER-WINDOW VIDEO OPTIONS
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
# FULL SCREEN OPTIONS
triplebuffer 0
switchres 0
full_screen_brightness 1.0
full_screen_contrast 1.0
full_screen_gamma 1.0
# WINDOWS SOUND OPTIONS
audio_latency 2
# INPUT DEVICE OPTIONS
dual_lightgun 0
readconfig 1
writeconfig 0
rompath roms
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath .;ini
fontpath .
cheatpath cheat
cfg_directory cfg
input_directory inp
state_directory sta
diff_directory diff
state
autosave 0
playback
record
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
burnin 0
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 1
sleep 1
speed 1.0
refreshspeed 0
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
artwork_crop 0
use_backdrops 1
use_overlays 1
use_bezels 1
use_cpanels 1
use_marquees 1
brightness 1.0
contrast 1.0
gamma 1.0
effect none
antialias 1
beam 1.0
flicker 0
sound 1
samplerate 48000
samples 1
volume 0
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
ui_active 0
offscreen_reload 0
joystick_map auto
natural 0
coin_impulse 0
mouse_device mouse
log 0
verbose 0
update_in_pause 0
debug 0
debugscript
debug_internal 0
# CORE MISC OPTIONS
bios
cheat 0
skip_gameinfo 0
uifont default
ramsize
confirm_quit 0
ui_mouse 0
inpview
inplayout
oslog 0
watchdog 0
priority 0
multithreading 0
numprocessors auto
profile 0
bench 0
video d3d
numscreens 1
window 0
maximize 1
keepaspect 1
prescale 1
waitvsync 0
syncrefresh 0
menu 0
hwstretch 1
d3dversion 9
filter 1
hlsl_enable 0
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
curvature 0.0
pincushion 0.0
scanline_alpha 0.0
scanline_size 1.0
scanline_height 0.7
scanline_jitter 0.0
defocus 0.0,0.0
saturation 1.0
offset 0.0,0.0,0.0
scale 1.0,1.0,1.0
power 1.0,1.0,1.0
floor 0.0,0.0,0.0
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
screen auto
aspect auto
resolution auto
view auto
screen0 auto
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
triplebuffer 0
switchres 0
audio_latency 2
dual_lightgun 0
don't understand what the big deal is , just send the correct
.inp files in
that's all
a mistake is a mistake
if you have the 41000 invaders game still
send it
you already have most of the 1st place positions anyhow
no biggie
pretty confusing hodge-podge of rom-sets
anyone could have blundered
.inp files in
that's all
send it
no biggie
yes, it gets confusing.
my problem now is when i record a game on 147, the inp folder remains empty. so i can no longer submit using 147 for now....
- simpsons99
you have to name the inp.kernzy wrote:yes, it gets confusing.
this caused me problems for awhile
Arcade Game Scores
Arcade Game Scores
for example, i normally trype in :
record kungfum kungfum
that has worked ever since i started using command lines. it has worked always, apart from the last 3 days. very confusing for me.
any advice would be very welcome...
- simpsons99
I copy and paste the name of the rom/inp that it's listed as.kernzy wrote:for example, i normally trype in :
I do this becouse Rom/name changes happen.
Arcade Game Scores
Arcade Game Scores
i do as well sometimes. does not help my dilemma....
Re: berzerk
http://replay.marpirc.net/inp/0/7/4/bea ... olf145.zip
it do not werk.
it do not werk.
- CrazyKongFan
- MARP Knight
Re: berzerk
Played back ok for metar wrote:http://replay.marpirc.net/inp/0/7/4/bea ... olf145.zip
it do not werk.
- 0000.png (1.12 KiB) Viewed 7593 times
Re: berzerk
it do not werk.
hey cool, this one works with sound! Get the humanoid, Kill the Intruder! it does NOT work with OUT sound.
Re: berzerk
Disabling sound should make no difference whatsoever in 0.145.
Re: berzerk
I get the same thing as Chad. With sound it plays back fine. If I disable sound with -nosound, it desyncs and only plays back to 4710.
-George
-George
- simpsons99
Re: berzerk
We are talking about Berzerk here you don'nt change any settings at all or it will cause recording/ Playback problems.
With that being said The score before this one was confirmed using wolf106 with a score of 45k something.. This score is alittle bit higher then that one at 48k
If it's playing back why has it not been confirmed yet?
whats the big deal?
whats the big deal?
Arcade Game Scores
Arcade Game Scores
Re: berzerk
first of all: no big deal.
second of all: If only two people confirm it works it's still in danger of being unplaybackable by three people, no need to confirm yet, but usually the first confirmer would confirm it anyway.
third of all: Where is the link to the marp page where you can confirm it? If you really need you recordings confirmed, don't complain, just post the marp link to it where the confirmer can easily click on it and then click confirm. I probably would have confirmed it if it was two clicks away and didn't have to type berzerk1 into the search page to find it.
fourth of all: I'm very curious if there really "should" be no reason for this to/not to playback because of turning on/off sounds: can Tar get this to playback after allowing -sound?
- simpsons99
Re: berzerk
I have no clue where the confirmer link is ... But i guess i have'nt been given the golden Key for thisChad wrote:first of all: no big deal.
Arcade Game Scores
Arcade Game Scores
