T12 - Round 1 - Mad Shark
Moderator: giro-X
The T12 starts to 00:00 GMT+1 (7days)
In this first round the game to play is Mad Shark (madshark) chosen by edusword.
MARPs record: 7,001,980 by WRX2 at 03 Aug 03 15:10:48
Good luck everybody.
Note:
+ 15 extra points if any player reach the MARP's record
+ It's mandatory to upload the scores in this post. If you want, you can do so at MARP.
Final Standings
Updated on 2012/02/27
Note:
Final Standings
Re: T12 - Round 1 - Mad Shark
OH NO!!!!!
good luck everybody!!
my arm is tired already.
it's quite mindless. sweep left and right and press fire as fast as possible. if i could use autofire i'd play it more...
after just a couple of minutes, i started using 2 fingers alternatively to fire, but it feels "false"...
You are too weak, kernzy
lol!!
My first score!!
3.774.510 - Final Boss (first loop)
INP WolfMAME 0.141:
http://replay.marpirc.net/inp/b/8/b/esw ... olf141.zip
Greetings!
INP WolfMAME 0.141:
Greetings!
Well here's my first go - I'll see if I can improve as the week goes along. Do I need to put the inp here as well??
- prf_madshark_538450_wolf141.zip
- (59.89 KiB) Downloaded 968 times
i can't avoid the orang bullets!!!
any advice edusword??
The orange bullets can't see as good as desirable in the first plays, I know it. But after some plays, you will see the bullets without any problem, don't worrykernzy wrote:i can't avoid the orang bullets!!!
It's difficult to give any advice playing this game. The reflex is very very important! The only advice is to use the blue laser EVERY TIME.
cheers mate. i watched saulo's game. it's bad when you gain firepower then die!!!
it's more enjoyable now
cheers!!
cheers!!
when i rotate the screen for maximum play area, i only get 80% of the screen. the bottom quarter is black....
- ballas
- MARP Knight
Just to double check, can we submit to MARP as we did with past tournaments with T12 in the description? I'm on 1094940 for now.
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
- Button Masher
Zerst - 2,590,780
http://replay.marpirc.net/r/madshark
824240
- pk-madshark-824240.zip
- (38.32 KiB) Downloaded 909 times
