T12 - Round 7 - Ketsui
Moderator: giro-X
empardopo
Post by empardopo » Mon Jan 07, 2013 4:22 pm
In this seventh round we are going to play to Ketsui game chosen by Zerstorung
The rom is ket
MARPs record: 242,573,313 by DX (@) (@)at 13 Jul 11 16:04:51
Good luck!
Note:
+ 15 extra points if any player reach the MARP's record
Final Standings
Updated on 2012/02/27
dickmoreland
Re: T12 - Round 7 - Ketsui
Post by dickmoreland » Mon Jan 07, 2013 10:32 pm
I'm guessing you can't use Wolfmame 106 for this game?
Post by mahlemiut » Tue Jan 08, 2013 1:34 am
You'll need 0.141 or later.
Back when 0.106 was released, this game would not be considered for inclusion in MAME (the unwritten 3 year rule).
empardopo
Post by empardopo » Tue Jan 08, 2013 5:17 am
To play this game you need 141 version. I think this game work fine with that version.
Greetings!
saulonpb2
Post by saulonpb2 » Tue Jan 08, 2013 7:47 pm
The Expert keyboard
Post by mahlemiut » Wed Jan 09, 2013 7:48 am
More lameness coming... ;)
br_t12-ket_11868675.zip
wolf147, SDL 64-bit
(164.94 KiB) Downloaded 340 times
empardopo
Post by empardopo » Wed Jan 09, 2013 3:30 pm
Are there any problem to play this game with 0.141 version?
Post by BeeJay » Wed Jan 09, 2013 4:05 pm
Aha.... tried this for the 1st time last night and it's another Cave bullet fest shooter.... a very nice surprise!! :)
Unfortunately I can only manage 58%, or thereabouts, on my main gaming computer so I'm going to have to revert to keyboard play for this one and use our faster laptop at home... or, hope I can finally source a PS/2 keyboard plug to USB converter that doesn't introduce a lag when using the HotRod controller.
1up
Post by 1up » Thu Jan 10, 2013 9:56 am
Very hard, even for a Cave game. Died on stage 2. My best ever is 25mill. so I will try harder.
http://replay.marpirc.net/inp/3/3/3/j8s ... olf141.zip
1up
Post by 1up » Thu Jan 10, 2013 9:58 am
empardopo wrote:Are there any problem to play this game with 0.141 version?
No. The game was officially added in v.141 and it plays just fine. older machines < P4 2.8ghz might have trouble keeping up over 95%
empardopo
Post by empardopo » Fri Jan 11, 2013 5:58 am
Please, remember
It's mandatory upload the score to MARP and add in the description the word "T12"
It's mandatory to use 0.106 or 0.141 version of mame
Thanks in advance!
simpsons99
Post by simpsons99 » Fri Jan 11, 2013 3:44 pm
empardopo wrote:Please, remember
Thanks in advance!
This game makes a NVRAM File each time with Wolf141
How can you target and shoot things? Seems to be alot more points in doing this.
Arcade Game Scores
1up
Post by 1up » Fri Jan 11, 2013 5:11 pm
Here's what I know so far.
When you shoot enemies they drop a green 'chip' with the value 1 - 5. The closer you are to the enemy when it explodes the higher the number. When you shoot an enemy you get a small countdown timer in the top left. While it's there, each enemy you shoot, with the target laser (hold shot button), drops a green 'chip' with the same value.
so, get close to a weak enemy and kill it with normal shot, then take out numerous enemies with the target laser, and collect as many 5point chips as possible.
These chips will add up on the large counter in the top left. When you reach a boss it will start to tick down. So kill the boss as fast as possible.
You get a end of stage bonus for:
chip counter
number of bombs left
and not dying.
hope that helps a little. Or even makes sense :?
Post by mahlemiut » Fri Jan 11, 2013 7:50 pm
It should be noted that your multiplier decreases when you use the target shot. So, you could increase the multiplier more first, then go for more target shots, which are multiplied. It's up to the player to figure out what scores better for them.
simpsons99
Post by simpsons99 » Fri Jan 11, 2013 8:06 pm
TY for the pointers they really helped to up my score! 2,293,236
Ketsui Kizuna Jigoku Tachi (20030101. Master Ver.) score 2,293,236.zip
(182.92 KiB) Downloaded 319 times
Arcade Game Scores
