just what i saidkernzy wrote:what do you mean, Brian, "This is another game the NES has wrecked for me ."
T12 - Round 10 - KungFu Master
Moderator: giro-X
- simpsons99
Re: T12 - Round 10 - KungFu Master
Arcade Game Scores
Arcade Game Scores
i do not understand, mate...
- simpsons99
game acts differently then the nes verson in which i allways played
Arcade Game Scores
Arcade Game Scores
just treat it as a different game.
"classic" is not date related.
a classic is something as good today as when it was released.
- pk-kungfum-621220.zip
- (71.44 KiB) Downloaded 1109 times
Not what I was expecting...
Can this 15 extra points be done a separate inp ?empardopo wrote: 3.- 15 extra points for whom have fewer points to the beginning of the third floor with a dragon (This extra point It's only for one player).
or you only look the inp with higher score ?
Only the inp with higher score! This rule is to try avoid leeching!Phil Lamat wrote:Can this 15 extra points be done a separate inp ?empardopo wrote: 3.- 15 extra points for whom have fewer points to the beginning of the third floor with a dragon (This extra point It's only for one player).
Greetings
Empardopo.
Kernzy, this inp is out of time, isn't it?kernzy wrote:...
- Marco Marocco
- MARPaltunnel Wrists
please delete this ruleempardopo wrote:Only the inp with higher score! This rule is to try avoid leeching!Phil Lamat wrote:Can this 15 extra points be done a separate inp ?empardopo wrote: 3.- 15 extra points for whom have fewer points to the beginning of the third floor with a dragon (This extra point It's only for one player).
Greetings
Empardopo.
it's enough this rule to avoid leech: "in 1st loop you must finish 2nd floor with max 70 K"
for the truth, you can also lecch in 2-2
please delete asap because 15 pts could be a random bonus
please othe players give your opinion
p.s.: please coordinator, can you spend 2 words about Zerstorung's Squash inp (poor Zerstorung, he was wrong cause too many T12's rules)
69570 in 2-3. Anti-points tactic! 108270 at end
- kungfum.zip
- (43.88 KiB) Downloaded 1043 times
Non sense, you will have anti leeching (for example people waiting to get into the stairs to get less time bonus) which is not better imoempardopo wrote:Only the inp with higher score! This rule is to try avoid leeching!Phil Lamat wrote:Can this 15 extra points be done a separate inp ?empardopo wrote: 3.- 15 extra points for whom have fewer points to the beginning of the third floor with a dragon (This extra point It's only for one player).
Greetings
Empardopo.
- Marco Marocco
Phil is right
The rule must be changed asap
that is a crazy rule. it might make the game more fun for a try, but it will make playing frustrating. i normally have 100,000 points after the 1st second floor, and 200,000 points on the 1st dragon. it will turn a beat 'em up game into a "run away 'em up"!!!
2 get only 70,000 points by 2nd floor 1 dragon is near impossible thinking about it....
should have another type of bonus. like highest score 1st man or something.
good luck, chaps!!
good luck, chaps!!
out of time, Emp?
is it too early?
lol!!
is it too early?
lol!!
