T14 Rules
Moderator: giro-X
Re: T14 Rules
Post by Phil Lamat » Fri Nov 06, 2015 11:03 am
Last commandline you give is the correct one :
mamearcade viostorm -record viostorm.inp -nvram_directory NUL -frameskip 0
But first did you check if you have a previous nvram subdirectory ? (in the directory where you have mamearcade.exe)
Because if so, You have to erase it first, then try the commandline
PG3
Re: T14 Rules
Post by PG3 » Fri Nov 06, 2015 11:41 am
23
Re: T14 Rules
Post by Phil Lamat » Fri Nov 06, 2015 11:58 am
PG3 wrote:I deleted a folder NVRAM
That explains why previous inp doesn't playback.
After recording your inp, check if another nvram folder has been created ;
the answer has to be no, if you still have one then it's the problem
PG3
Re: T14 Rules
Post by PG3 » Fri Nov 06, 2015 12:10 pm
24
Re: T14 Rules
Post by Phil Lamat » Fri Nov 06, 2015 1:51 pm
NotMan wrote:Amidar have been updated.
- 0.142u4: Patrik Styrnell added Amidar (Konami 1982). Renamed (amidar) to (amidar1).
All is in proper place now
Notman, your 1337040 has disappeared as it was recorded on same set (now amidar1) than your incredible 2999980 ...
I guess you're back to work :wink:
Re: T14 Rules
Post by mahlemiut » Fri Nov 06, 2015 5:55 pm
PG3 wrote:There is no "hiscore.dat"
1 sample: mamearcade viostorm -record -nvram_directory NUL viostorm.inp
2 sample: mamearcade viostorm -record -nvram_directory NUL -frameskip 0 viostorm.inp
OKAY?
The INP filename is a parameter of -record, you must put it after -record.
So:
krehztim
Re: T14 Rules
Post by krehztim » Fri Nov 06, 2015 10:06 pm
Thread was a little confusing. Are we doing amidar or amidar1, or does it matter?
amidar_52190.zip
(224.82 KiB) Downloaded 172 times
simpsons99
Re: T14 Rules
Post by simpsons99 » Sat Nov 07, 2015 12:18 am
still trying to shake off the Zupapa rust
Wolf Mame 106
Here you go for now 2,147,500
zupapa score 2,147,500.zip
(55.59 KiB) Downloaded 163 times
Arcade Game Scores
NotMan
Re: T14 Rules
Post by NotMan » Sat Nov 07, 2015 12:27 am
I guess that we play amidar instead amidar1. Amidar1 is probably the easiest version and it can be marathonable. Amidar is pretty close same as Amidar (Stern version), afaik. @Phil. Actually I did 5m something on amidar long time ago, but I took it off and replaced with that 2.999m replay.
Re: T14 Rules
Post by Phil Lamat » Sat Nov 07, 2015 4:02 am
Yes we play amidar, and you must use wolf166 (the actual amidar wasn't avalaible under 106).
I agree with Notman, amidar1 (1981) is the easiest version : you have 4 jumps for each level, and an extra life every 50k (30k, 80k, 130k etc infinite).
As it was marathonable, amidar (1982) came back but with 3 jumps only
And if you want to play hard version, as far as I remember, amidaro (amidar from Olympia) has only 1 jump per level
PG3
Re: T14 Rules
Post by PG3 » Sat Nov 07, 2015 4:18 am
25
Re: T14 Rules
Post by Phil Lamat » Sat Nov 07, 2015 4:31 am
PG3 wrote: But now I recorded from the command line
and I had no NVRAM folder after recording and it was desynch.
Can you post one of your desync inp, I gonna try other test.
But I'm afraid there is a problem here.
Up to the tournament coordinator to decide what to do ...
PG3
Re: T14 Rules
Post by PG3 » Sat Nov 07, 2015 4:52 am
26
PG3
Re: T14 Rules
Post by PG3 » Sat Nov 07, 2015 5:42 am
27
PG3
Re: T14 Rules
Post by PG3 » Sat Nov 07, 2015 7:09 am
28
