The J.League 1994 (Japan, Rev A)
PP.
Post by PP. »
There is a playback issue with this rom(jleague) which I've detected from last May,
playback shows normally only first match, then goes crazy.
Phil has uploaded an inp with scores in second and third game, but you won't see them.
So, shoud we add a special rule about only first match?
Re: The J.League 1994 (Japan, Rev A)
No special rule because playback doesn't work.
We just have to wait till playback problems will be fixed for this game
PP.
Post by PP. »
Phil Lamat wrote:No special rule because playback doesn't work.
And meanwhile we'll have scores which do not agree with playback?
I guess you have to edit your score to 105, as I did too. Otherwise anyone can claim any score.
Or have it zeroed because no one can play it back. Need to start maintaining a list of games with problematic playback again, it's just really hard to keep updated.
Score adjusted. I've made several tests (no sound, constant frameskipping etc) but game still desyncs on second match.
Parent (svf) was ok with older versions. Some stuff for Mame dev
PP.
Post by PP. »
What about "jleagueo", is it a diffrent game? You inp says "jleague".
And what about "dsaber", after so many months vaz's score of 32040 still remains there.
What was jleague under 0.106 became what is jleagueo now.
PP.
Post by PP. »
Phil Lamat wrote:What was jleague under 0.106 became what is jleagueo now.
Maybe this should be written in special rules?
So, if I play "jleague" in under 0.106, it will be "jleagueo"?
Playback is normal?
PP. wrote: Maybe this should be written in special rules?
Done (for jleague)
PP. wrote: So, if I play "jleague" in under 0.106, it will be "jleagueo"?
Yes, if you play jleague with 0.106, you will have to submit under "jleagueo" on Marp.
A classic problem, can be avoided now when reading special rules for Jleague.
All mame renames bring a bit of confusion as usual
PP. wrote: Playback is normal?
I guess ; my 0.106 inp seems to playback perfectly.
I suppose something has changed between 0.106 & 0.174 which brings the desync
