bea99_chwy_41000_w189
giro-X
Post by giro-X » Fri Sep 22, 2017 4:09 pm
http://replay.marpirc.net/r/chwy
http://replay.marpirc.net/inp/2/b/6/bea ... olf189.zip
Actually just wanted to say it playbacks correctly, upload confirmed.
Phil may have had issues at playback if he used turbo speed while the coin was being inserted. It happened to me also on a second, all fastened, playback.
Coin is being inserted near frame ~13700, you can use turbo before and after that, but not in that precise moment.
edit: just tested Phil's replay, by unlocking speed the same effect happens, all regular at 100% speed.
Just leaving a memory in case of playback issues with this or other DECO cassette system games.
Haze
Re: bea99_chwy_41000_w189
Post by Haze » Fri Sep 22, 2017 4:33 pm
that sounds an awful lot like a MAME bug
% speed shouldn't make any difference to game logic or if a coin is inserted or not
if it does, the reason why needs to be tracked down and fixed
I'd guess it's something to do with the PORT_IMPULSE logic in replays when frames get skipped, in which case the logic is broken in MAME, because it should not be affected by frameskip.
Post by BeeJay » Fri Sep 22, 2017 5:47 pm
I've changed the comments on Brian's upload to reflect this and added a reference this forum posting.
Post by Phil Lamat » Fri Sep 22, 2017 5:52 pm
Yes, I've pressed F10 at the beginning of the playback.
It's new to me that it can affect the playbackability
simpsons99
Post by simpsons99 » Fri Sep 22, 2017 6:47 pm
I did not coin this one up right away .. I would start The rom and go to other screens and come back .. Most of the time it was about the time for the game to load.
for this game something kept me from making it back to the game faster .
Yeah I f10 my recording and watched it .. everything is good on my end.
Arcade Game Scores
Post by mahlemiut » Fri Sep 22, 2017 7:26 pm
I came across this issue when watching cgraplop2 INPs. Essentially coin inputs can be missed when skipping frames. Running unthrottled is fine, however. So for any DECO cassette game, at least, just be weary when using frameskip or fast-forward when watching or recording INPs.
simpsons99
Post by simpsons99 » Fri Sep 22, 2017 8:39 pm
well i just beat the score .. Should i post the recording here first or just upload it
Arcade Game Scores
giro-X
Post by giro-X » Fri Sep 22, 2017 10:22 pm
simpsons99 wrote:well i just beat the score .. Should i post the recording here first or just upload it
Don't worry, submit on MARP directly :)
