clones of Wboy
moreno-df
clones of Wboy
Post by moreno-df »
I have 2 clones of wboy ( wboy4 and wboy4u ), not have in the marp this clones for submit.
M O R E N O - D F. :D
Abbe
Post by Abbe »
All of the Wonderboy sets were renamed somtime during the b37-cycle.
As I recall it the romset names were changed like this:
Old name -> new name
wboy -> wboyo
wboy2 -> wboy3
wboy3 -> wboy
wboy4 -> wboy2
wboy4u -> wboy2u
Since MARP uses the latest rom names this means that if you want to submit a wboy4 game recorded with mame 36 you have to submit it as wboy2.
gameboy9
Post by gameboy9 »
I was wondering about that...
http://gameboy9.marpirc.net
cso2040
Post by cso2040 »
:?: And what should I do if I want to submit a recording for a clone that is not listed at the records page?
cso2040 wrote::?: And what should I do if I want to submit a recording for a clone that is not listed at the records page?
I think the answer to that is you can only submit gamenames that are valid for the current latest version of mame. If you have a recording with an older version of mame that maps to "gamename1" you'll have to find the name change history (once available from http://www.mame.dk) to get which current "gamename2" mapped to "gamename1".
In other words, get the latetest version of mame, do mame -listclones wboy , and the output of that will show you which versions of wboy are available for current submission.
Kale
Post by Kale »
So,what's the need in having in the database removed sets like rtypeb or gcastle?
i couldn't find rtypeb's but the gcastles I found should have been moved to the right clone rom name that took over it's rom. Mistakes happen or more likely things don't get done because there's lots of other stuff to do.
From Abbes's response, if you record wboy4 with an older version of mame you must upload as wboy2 (and state in the description that you used wboy4 romname), if you record wboy4u use wboy2u, etc. Or you can just use the current version of mame and play the game name that you record, mame wboy2 -record wboy2
cso2040
Post by cso2040 »
Chad wrote: I think the answer to that is you can only submit gamenames that are valid for the current latest version of mame. If you have a recording with an older version of mame that maps to "gamename1" you'll have to find the name change history (once available from http://www.mame.dk) to get which current "gamename2" mapped to "gamename1".
Thanks for your reply Chad but I wasn't refering only to wboy, actualy I was refering to a clone (of any game) that is valid for the latest version of MAME and it's not listed at the records page (i.e. there are no records for that particular clone) for example: xmcotau is a clone of xmcota in the current version of MAME, but there are no recordings for this clone at MARP. So my question would be: can I submit recordings of games that are not listed at MARP even when they are valid for the current MAME release?
(Sorry for my Engrish :oops: )
If there are no scores for a game, then it's pretty likely that it doesn't work (either the clone itself, or just playback). But if it does, then you're lucky. :)
cso2040
Post by cso2040 »
mahlemiut wrote:If there are no scores for a game, then it's pretty likely that it doesn't work (either the clone itself, or just playback). But if it does, then you're lucky. :)
Well, xmcotau works fine and seems to playback correctly.
I think I am lucky. :mrgreen:
cso2040 wrote:Well, xmcotau works fine and seems to playback correctly.
Must check that set out then. ;)
