Hi,
I just bought a 'Magic Box' (an USB-adapter for Dreamcast conctrollers [and PS II, Saturn]). Well, probably it's not the original 'Magic Box' as you get it from
http://www.lik-sang.com/info.php?catego ... ts_id=1939
but some copy of it bought at http://www.play-asia.com/.
I plugged my Dreamcast Arcade-stick to it and tried using it with alphamame32-0.67 playing Crazy Kong. The 'Jump'-button works fine but I am unable to move.
In 'Control Panel/Game Controllers' there is a new Device ('USB Human Interface Device'). If I open 'Properties/Test' for it and use the joystick I see that some buttons are pressed.
But I don't know how to tell Mame that it should use these buttons as input for direction movement.
Can anyone tell me whether I have to configure the USB-Device or Mame?
And HOW?
bye,
michael
How to configure magic box (dreamcast adapter)
Buttermaker
In MAME32 all you have to do is "Enable joystick input" under Controllers.
It sounds strange that some buttons are pressed.
There is an FAQ at Lik-Sang. Maybe that can help you: http://www.lik-sang.com/faq.php?browse= ... ries_id=54
Does the stick work fine there when testing it?In 'Control Panel/Game Controllers' there is a new Device ('USB Human Interface Device'). If I open 'Properties/Test' for it and use the joystick I see that some buttons are pressed.
I did that.Buttermaker wrote:In MAME32 all you have to do is "Enable joystick input" under Controllers.
Well, the testing area is divided in two parts: 'Axes' and 'Buttons'.Buttermaker wrote:Does the stick work fine there when testing it?In 'Control Panel/Game Controllers' there is a new Device ('USB Human Interface Device'). If I open 'Properties/Test' for it and use the joystick I see that some buttons are pressed.
In the 'Axes' part you see a little cross that probably should move if I use the joystick (but it doesn't).
In the 'Buttons' part you see a lot of numbers (1 - 16) that are highlighted if you press one of the buttons on the joystick (works fine).
But if I move the joystick also some numbers are highlighted (left:16, right:14, up:13, down:15).
It seems as if the directions are also mapped to buttons (that might be correct, since the arcade stick is no analog joystick).
Maybe, I have to tell Mame somehow that it should use these buttons as input for directions.
I looked through the FAQ, but it only says that the Arcade stick should work.Buttermaker wrote: There is an FAQ at Lik-Sang. Maybe that can help you: http://www.lik-sang.com/faq.php?browse= ... ries_id=54
Buttermaker
It works, thanks a lot.Buttermaker wrote:Start a game, hit tab, select "Input (General)", move to "P1 Up", press Return and move your stick up. That will configure the P1 up key for every game.
Finally, I have some use for that Dreamcast Arcade stick. I just bought it because it was cheap and I wanted to use it for playing mame on the dreamcast (but I don't like that version of mame).
Buttermaker
