I've been /away from my computer couple days, haven't tried it yet.DRN wrote:Tommi,
Have you tried your spinner for 720 yet? I have a nasty feeling it may not work as the mamedevs changed the controller system for this game from dial to joystick at about 0.85. It no longer works for me anyway! I just get straight up, down, left, right movements.
Little regulation catching up to do.
I think you're right though. MAWS shows controller as a "stick", and I remember reading somewhere that there was controller emulation update for 720...So that original controller is emulated now, so that you could hack an original 720 arcade controller to play with MAME.
Usually when stick is emulated contoller, you can play with mouse too(starwars etc)...In the case of 720, it might be that because the stick movement is so strange, mouse might not do the trick. I don't know if there's workaround this using controller cfg file.
I might ask mame board if it still can be played with mouse, or even to add old type of mouse support, since not many are going to play it with original controller anyway...
Ideal would be of course to have original optical spinning stick AND old kind of mouse x-axis drivers BOTH emulated, 2 different drivers for 2 different contollers...If it can be done separately, that is...if not, maybe simple switch could be added to choose from old control driver vs new.
Too bad if new contol driver messes up spinner play. Maybe Haze reads this?
