I had Wlfmame 106 and it didn't let me "pause"
Looking for wlfmame 106 command line for TG complience NOT the gui mameplus.. previously i had it installed on my cab, don't know what happened I wasn't able to hit pause which is good because i know that's not allowed, now i am able to pause it ? so can any one point me to the command line wlfmame 106 complience for TG settings file
- destructor
- MARPaholic
Re: I had Wlfmame 106 and it didn't let me "pause"
You can't pause game during recording inp, during normal play you can pause game.
Never mind if you use GUI or command line, both are accepted.
that link is to wolfmame plus 106, i don't want that i want the command line and cant seem to find it any where wolf mame plus does seem to load on my system it comes up with blank grey bars.. still seeking command line version of MAME 106
? Just run it with a game name as a parameter, it should work as cli.
http://wolfmame.marpirc.net/wolfmameplus-0106.exe
mamep106-vc.exe = commandline interface
mamep106gui-vc.exe = GUI interface
Older standard MAME versions are at http://mamedev.org/oldrel.html
just launches a grey box and wont launch any games
Sounds like either you're not running it from a command prompt, so that any error message would be missed, or you're stuck at the broken game info screen, in which case you just press enter to continue.
well the pause now works again.. however.. ok so really weird screen looks like this when launching game :
then if i hit "enter" it will let me play it .. however when i go to play-back the file it immediately displays : "recording stopped" ??? and doesnt play-back game play?
im running a .bat as a command
mamep106-vc gunsmoke -record gunsmoke.inp
mamep106-vc gunsmoke -record gunsmoke.wlf
and then for play-back:
mamep106-vc gunsmoke -playback gunsmoke.inp
then if i hit "enter" it will let me play it .. however when i go to play-back the file it immediately displays : "recording stopped" ??? and doesnt play-back game play? im running a .bat as a command
.wlf files are created automatically. You don't need to do anything to create them, it'll appear after recording.
Basically, remove that second line from your recording batch file, and you should be fine.
That screen you show is the broken game info screen, so just ignore it. It's caused by a bug in the Visual C++ compiler.
just hit the ENTER key to get past that screen.
