K7 - Round 1 - Part 2 - View Point (viewpoin)
Kale
Re: K7 - Round 1 - Part 2 - View Point (viewpoin)
Post by Kale »
sikraiken wrote:I'm not sure how well save states transfer from machine to machine, but it's attached (wolfmame106).
My guess is that you need to upload your default.cfg and viewpoin.cfg files as well,but it's strange,in theory save states are mainly for bug testing -> a talented player plays,saves the state and the developer use it for fixing purpose.
sikraiken
Post by sikraiken »
Alright, here are those files. Make sure "Enable game cheats" is selected as well (under miscellaneous), or else the save state doesn't work I think. These files go in the cfg directory.
Stage 3 1-up requirements:
-Destroy the two black balls at the same time.
-Destroy all centipedes.
One time I got a star instead of a 1-up, somehow. Ghemant, a star is better than a 1-up score-wise (in-game scoring), but not with how your targets are set up. ; )
defaultandviewpoin.zip
(770 Bytes) Downloaded 486 times
sikraiken wrote: Ghemant, a star is better than a 1-up score-wise (in-game scoring), but not with how your targets are set up. ; )
yes, I'm unison with you :mrgreen:
but.... :?:
every life = max 200.000 pts if you are a very good player in this game.
sikraiken
Post by sikraiken »
but.... :?:
Again, your targets. :D
If you want a high score without miss lives, you can obtain all 14 Nazo bonus :wink:
I don't know for others, but for me target A sucks : it forces me to restart level 1 80% of the time.
Should be able to claim the bonus if target has been reached once, even not in final inp
sikraiken
Post by sikraiken »
Maybe if I had a VHS tape of the arcadia record like some people... ; )
Ok, now I got it to work and can indeed get the 6 stars very easily now doing the same things I was doing with my own state. Have no idea what the difference could be. Have you ever managed to get the 6 stars on a complete regular game?
I also noticed that using your state, the satellites near the end drop a star as the 3rd last item (lower right side of the screen). No matter what I do on my games I always get an F bomb (heh). Noticed the items there are sometimes bombs when you are in need of them but even with full bombs I always get the F.
Similar problem with the 1 up, I destroyed everything starting from the first bee wall and only got an F right before the caterpillar crossing.
sikraiken wrote:Maybe if I had a VHS tape of the arcadia record like some people... ; )
VHS isn't sufficient because arcadia record is with autofire. If you use autofire you obtain a nazo bonus with facility. But if you don't use, all game change. After many years, I can say that high score (like arcadia) is possible also without autofire, but all pattern change.
sikraiken
Post by sikraiken »
VHS it isn't sufficient because arcadia record is with autofire. If you use autofire you obtain a nazo bonus with facility. But if you don't use, all game change. After many years, I can say that high score (like arcadia) is possible also without autofire, but all pattern change.
It still gives you the great benefit over everyone else of seeing where the nazo are. I'll be getting the Mission Impossible 2, anyway.
The_Pro wrote:Ok, now I got it to work and can indeed get the 6 stars very easily now doing the same things I was doing with my own state. Have no idea what the difference could be. Have you ever managed to get the 6 stars on a complete regular game?
Yeah, I've managed to get 6 stars in a complete regular game. For the end of stage 6 and 1-up in stage 3, it seems like you need full bomb stock.
Ok, figured some things out. In order to get the six stars and the 1-up on the third level you must have three bombs, one of each kind. I didn't keep going but I'm 99% sure that this will also give you a star for the 3rd last item that would otherwise be an F.
In addition, you don't have to kill the black orbs on level 3 at the same time. I went the whole way without bombing.
I don't even know if I'll have time to take advantage of this, so swamped. If I don't upload something else by tuesday night then I won't at all.
The_Pro wrote:Ok, figured some things out. In order to get the six stars and the 1-up on the third level you must have three bombs, one of each kind. I didn't keep going but I'm 99% sure that this will also give you a star for the 3rd last item that would otherwise be an F.
8O
this game is so silly.
sikraiken
Post by sikraiken »
Thanks for figuring that out, Martin.
ballas
Post by ballas »
What is nazo?
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
ballas wrote:What is nazo?
Your ship's side pods, which is equivalent to picking up a gold star if you already have them.
