GEGOTW 2012 - GAME 1: KUNG FU MASTER
I can't get wolfmame106 to work with my Hori Real Arcade Pro VX-SA stick. The stick itself is usually recognized as a hat-switch and theres no way to change that like on the Madcatz SF4 Tournament Edition sticks. My stick works fine with MAME145?
Is joy2key the only option?
It should work with any joystick that Windows recognises.
That being said, I'd like to use 0.146, since it would save me having use Wine to make recordings (I'm not a Windows user, remember)
Im pretty sure it said somewhere that we were to use wolfmame106? Im all for using whatever version of mame we like as my stick works on mame145mahlemiut wrote:It should work with any joystick that Windows recognises.
- Marco Marocco
- MARPaltunnel Wrists
5) Official emulator: wolf 106
About the default settings, it goes by default
Actual leaderboard:
1) Empardopo 404.120
2) Potante 326.440
3) RAX 244.980 (with much much leeching on 1-2)
4) Phil Lamat 193.960
5) Beejay 113.900
Bonus points:
Empardopo 5
Potante 3
RAX 1
Slow beginning, I hope we'll have better scores
Sucks that my stick doesn't work.
76,310
76,310
- kungfum-1up-76310.zip
- (11.63 KiB) Downloaded 431 times
- TRB_MetroidTeam
- MARPaholic
Hi guys! How can I jump forward consistently??? Any tips? Usually it jumps in the same place, and rarely I can jump for the sides. I already tried joystick and keyboard.
- Marco Marocco
We've discussed about this problem on Arcade Extreme.
Someone thinks it's an emulation problem, someone suggests to move a little bit forward and then up.
you need to roll your joystick round, and already be moving. it's near impossible to jump sideways from a stationary position.
i think this entry ended with a credit afterwards. don't know how that happened. do i need to do a new one??
- pk-kungfum-610600.zip
- 5th try.
- (57.8 KiB) Downloaded 434 times
That's right,and In addition:kernzy wrote:you need to roll your joystick round, and already be moving. it's near impossible to jump sideways from a stationary position.
Valter,as a SF player imagine to play as Guile instead of that Thomas,and try to push diagonals only after holding AT LEAST a second in any of left/right positions.
That's the only way it works,after a little tries you can jump forward consistently,try to believe it
whats the deadline for kungum inp's?
and whats the 24 hour 15 years old limits about? well confusing...
From the opening post to this topic: Deadline for submission to MARP: June 11, 2012 19.59 hours GMTkernzy wrote:whats the deadline for kungum inp's?
24 hours refers to how long after you make the recording before submitting it. So people don't sit on a good score and submit it at the last minute.kernzy wrote:and whats the 24 hour 15 years old limits about? well confusing...
The 15 year old comment is referring to the fact that we shouldn't sit on good scores anyway because we're all adults, not 15 year old kids.
lol!
cheers Brian!
cheers Brian!
Wow,fantastic score! You are in the first positionkernzy wrote:you need to roll your joystick round, and already be moving. it's near impossible to jump sideways from a stationary position.
1up wrote:Im pretty sure it said somewhere that we were to use wolfmame106? Im all for using whatever version of mame we like as my stick works on mame145mahlemiut wrote:It should work with any joystick that Windows recognises.
Really wish you would allow newer versions of MAME since I'm in the same boat as 1up, wolf106 does not recognize my joystick. If you mess around enough you can get joy2key to work, but it's more likely to drop inputs through that.Marco Marocco wrote:General topic:1up wrote:
K10 will definitely allow players to use a newer version of MAME when that tournament rolls around.
I will try to improve, but not play better!
- kungfum.zip
- nii-san 57.870. 2nd floor
- (12.52 KiB) Downloaded 421 times
