after I put dkong3 for both of them? Should It Load the game?
Nothing happens ..
Recent Verisons of Mame Recording problems
- simpsons99
Re: Recent Verisons of Mame Recording problems
Arcade Game Scores
Arcade Game Scores
This 'improved' Record.bat file is great
(I added -video ddraw and -window)
To make it foolproof, maybe give user a written feedback if the game/rom is not complete..: I had an incorrect rom for dkong3 and the new Record.bat will just blink black and close quickly //"What happend?"// c",)
Another reason why you should run it from a command prompt, otherwise you miss out what can be rather useful information.DaLar wrote:This 'improved' Record.bat file is great(I added -video ddraw and -window)
- simpsons99
Can you see I am trying to figure it out .mahlemiut wrote:Another reason why you should run it from a command prompt, otherwise you miss out what can be rather useful information.DaLar wrote:This 'improved' Record.bat file is great(I added -video ddraw and -window)
Arcade Game Scores
Arcade Game Scores
- simpsons99
I think I figured it out .. How do I play back Inps now? I did a test game of Raiden 2
Arcade Game Scores
Arcade Game Scores
playback.bat works exactly the same as record.bat does (expect that it plays back the INP, instead of recording one obviously
I changed of few words in the 'improved' Record.bat and re-named it PlaybackPrompt.bat
- playback prompt.zip
- (645 Bytes) Downloaded 293 times
- simpsons99
yep that worked ty!DaLar wrote:I changed of few words in the 'improved' Record.bat and re-named it PlaybackPrompt.bat
Arcade Game Scores
Arcade Game Scores
Good to see/hear.DaLar wrote:This 'improved' Record.bat file is great(I added -video ddraw and -window)
You could add a new line at the bottom of the file which reads:
pause
That will stop the black window closing so you can see the information from MAME.
Oh, I also discovered that CTRL+C doesn't stop the batch file like it says it should. Mea culpa.
