WolfMAME - not plus
- destructor
WolfMAME - not plus
Barry, why you use official MAME version for wolf? In plus version is more features.
For the ease of keeping it updated. Between Aaron's core rewrites, and various other changes, it was getting to be a right pain in the ass to do updates. Now I've just split everything up into source modules, and each one can be worked on seperately.
There is no reason why someone couldn't just apply the patch to MAME Plus (when it's released) but this also eliminates possible problems that could be caused by MAME Plus.
I do intend to create modules for the input viewer and INP captions eventually.
- destructor
Hi...
I'm not sure i understand well but finally, why do you make a wolfmame version if everything is the same than a mame version ?
And further in command line
I always recorded with the gui version to see my own snapshots and now all is gone
Thank you for the precisions, i will ask french friend to help me to install a frontend.mahlemiut wrote:It still records speed as it has always done. It still disables pausing as it has always done. These are the core important things. If you want a GUI, use a frontend, or build your own based on MAME32 or MAME Plus.
I don't have the knowledge to build my own version of mameplus.
Cheers.
Even better idea... learn to use the commandline. I even included record and playback batch files with the binary.
Even nicer would be a GUI compiling app. Something along the lines of the XFCE (X-Windows window manager) installer which simply tells what you require to build, and if you have everything needed, compile and install it at a mouse click.
- TRB_MetroidTeam
I haven't tried it yet, but I'm sure this is a step forward... making a derivative version of a derivative version is not a good idea.
The only downside I can think of is that maybe it will not be as popular as wolfmame-plus because it doesn't have multi-language support, but who knows, maybe a future version brings that.
