I've been looking at minivadr recordings and it looks like
it is not clear what should score be for this game. some reported
number of points = number of rounds cleared and other = last round played. I think it should be like this if you cleared 8 rounds you get 8 points.
First recording is only confirmed and it was confitmed wrong
LordGaz cleared only 6 rounds but he has 8 points
other all reported 7 points and here's what they did
game guru cleared 7
a.d.sakuragi cleared 7 also
QRS , virtualgaz, timmykins all cleared 6 rounds
gmitrovic@junis.ni.ac.yu
						minivadr scores
Thanks for bringing this point up, lord gaz actually does clear all 8
levels and completes the game, as confirmed, but you're right about
the three people reporting 7 but really only cleared 6 levels.
should all be fixed now, can you try Lord Gazes again to see if he
clears all 8? are you sure you're using a mame37b10 version?
churritz@crash.cts.com
another pretty good feat lord gaz did (in addition to completing all
8 levels) was get 4 out of the 7 saucers that fly by, and it's
mame36b15 that you'll need to playback lord gaz's game.
				Gmitra
Actually i didnt try it with 36b15 because i dont have it , and it is not available for download at mame.net. I tryed it with 36rc1 closest thing i had . And for cheating i didnt notice that , since im new i really dont know how to spot cheating.
yeah nothing that looked like cheating here.  But to mention you can
get the mame version with the "Get Mame" link near each recording.
sometimes it doesnt work but usually with older versions it's the
best way to get the older mame to play the game back.
				Gmitra
Okay i downloaded file, but it only has exe file nothing else so now
it wont run without audiow(something).dll file . Thats why i dont like trying mame32 recordings and it will probably make a mess of my registry when i start new then old then new mame again
				Joe Ledesma
Go here for that file - http://marp.retrogames.com/diffs.htm
It's under the MAME32 section, usually people need it.
JoeyL21988@yahoo.com
I agree with you about the mame32 playing backs, it's a nightmare and
sometimes it's even worse than a nightmare when the registry keys
must be cleaned before the recording will playback because the later
version of mame32 left the registry keys in an incorrect state that
the old mame32 will assume is right.... incidentally i didn't even
use the mame32 version to play his recording back i used the dos
version m3615 and it worked. sometimes the windos recordings
playback in dos mode but not always.
